How to split a drawing along a line or axis
burkecorp
If possible I'd like to jave someone advise how I can split a drawing along a line or axis.
For example if I have a house plan I'd like to be able to split the plan along a reference line by a certain distance and then extend the lines to meet again once the reference line is deleted if possible?
yes I'm trying to split a building along a reference line then move everything say above that line a certain distance and delete the reference line and join the split lines back together.
yes it looks as though that option may work. as my login suggests I'm only a newbie and i really appreciate your help
all the way here in australia
Make a copy first, and rename the original something else so you won't overwrite it. Work on the copy drawing, then if it works, "save as" the original name.
AutoCAD newbie? You might want to stop and look at some of the tutorials here at CADTutor before proceeding any further.
Welcome to the CADTutor forum.
