vernonlee Posted July 28, 2015 Share Posted July 28, 2015 Is it possible to open all levels of nested block at the same time for editing? Due to the nature of this work, the items i need to edit are all in different levels of nested blocks & i keep having to "edit in place" to amend 1 block, save then close block, then go "edit in place"another block, save then close & repeat many many times. Due to the nature of the drawing, I am not able to update 1 block at a time Appreciate it the help. Thanks Quote Link to comment Share on other sites More sharing options...
vernonlee Posted July 30, 2015 Author Share Posted July 30, 2015 Is it possible? Or any workaround? Quote Link to comment Share on other sites More sharing options...
iconeo Posted August 5, 2015 Share Posted August 5, 2015 As far as I know this isn't possible. It might be better to use dynamic blocks setup with visibility states and lookup tables. Then you can use BVMODE and change a bunch of stuff all at once while still being able to separate things out as needed. Just a thought. Quote Link to comment Share on other sites More sharing options...
vernonlee Posted August 5, 2015 Author Share Posted August 5, 2015 As far as I know this isn't possible. It might be better to use dynamic blocks setup with visibility states and lookup tables. Then you can use BVMODE and change a bunch of stuff all at once while still being able to separate things out as needed. Just a thought. I see. Most of the existing block would be normal blocks though. They are just blocks within a block within a block ......... Many levels deep. Quote Link to comment Share on other sites More sharing options...
iconeo Posted August 5, 2015 Share Posted August 5, 2015 If you can post one I'll show you what I mean by converting it into a DB. Quote Link to comment Share on other sites More sharing options...
