FlashTzu Posted August 4, 2015 Share Posted August 4, 2015 I am looking for a way to label points on my design as easily and quickly with the coordinates. Id like to annotate using a leader that will give me the X,Y coordinates of the point I select. Basic Example. X 27.2843 , Y 2.331 ----------------------------------> . 2nd Thing. I would like either on the same leader or a separate one if need be to annotate the distance from the point to the center of the curve. X 27.2843 , Y 2.331 ----------------------------------> . A 2.34 , B 4.22 A is distance from x to 0 of the curve. B is distance from Y to 0 of the curve. P.S. sorry if this is a common question please link to thread(I have been looking unsuccessfully) thank you for your time. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 5, 2015 Share Posted August 5, 2015 Pretty sure you can set up a leader with a field XYZ etc 2nd may need a lisp 3rd Google should have revealed this, try http://www.lee-mac.com label.lsp label point XYZ Autocad revealed lots Quote Link to comment Share on other sites More sharing options...
Dana W Posted August 5, 2015 Share Posted August 5, 2015 The X and Y values locate a single point in a 2D matrix. I don't understand how either value separately can have relevance to any other point. The X value can occur at infinite locations along the Y axis, and the Y value can also occur at infinite points along the X axis. Be that as it may, use a multi-leader with a User-Block containing one or more fields. The coordinates can be found in Object Properties in the field insert dialog. You can select for X, Y, and/or Z, one at a time or all together. I was looking at the field insert dialog but could not find a way to obtain a distance between two objects, but I didn't spend much time at it. I am sure it can be done. An easier way might be a dimension with all lines and arrowheads suppressed or turned off. EDIT: See why I didn't spend much time looking? I knew BIGAL would beat me to it. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 5, 2015 Share Posted August 5, 2015 Dana you elaborated more about using fields thanks Quote Link to comment Share on other sites More sharing options...
FlashTzu Posted August 5, 2015 Author Share Posted August 5, 2015 Thank you Very much for the help I have figured out how to add x,y to a leader Leader insert field object -select line end I now would like to repeat this process with out doing all 5 steps every time is that possible? Or do I need to find a lisp for that? Quote Link to comment Share on other sites More sharing options...
