GetExcel and PutExcel command
raj patel
i am new in autolisp please explain what the getexec, GetCell and putexcel command...
(GetExcel "G:/FR_X/drline.csv" "drarc" "A20")
what meaning of this command?
also this code explain.
(command "cutclip" ss33 "")
(command "pasteclip" point1 "")
GetExcel looks like a lisproutine to retrieve data from cell "A20" , sheet "drarc" file "G:/FR_X/drline.csv" but as it is a csv file no telling exactly what the routine does because that all depends on the contents or format of the file.
The other commands are partly standard autocad (google cutclip / pasteclip). Lisp routine has made a selection and saved this selection in variable ss33 , cuts it and pastes it (effectively move it) to coordinates saved by routine in variable 'point1'.
gr. Rlx
Edited by rlx
Getexel.lsp is a very good to/from excel & Autocad program, it may have a read csv as a option, the version I have does not, but it appears to be around 2008 version, perhaps their is a newer one.
Overview of Main functions
; GetExcel - Stores the values from an Excel spreadsheet into *ExcelData@ list
;   Syntax:  (GetExcel ExcelFile$ SheetName$ MaxRange$)
;   Example: (GetExcel "C:\\Folder\\Filename.xls" "Sheet1" "L30")
; GetCell - Returns the cell value from the *ExcelData@ list
plus lots more options
(defun putexcel ( _file _lst flag / _excelapp _workbooks _ws _tbs _cells )
 (if
   (and
     (setq _excelapp (vlax-get-or-create-object "Excel.Application"))
     (setq _workbooks (vlax-get _excelapp "Workbooks"))
     (or
       (and (findfile _file)
         (setq _ofile (vlax-invoke _workbooks "Open" _file))
       (and (setq _ofile (vlax-invoke _workbooks 'Add))
         (vlax-invoke _ofile 'Saveas _file)
     (vlax-for w (vlax-get _excelapp "Sheets")
       (setq _tbs (cons w _tbs))
       (cond
         ( (eq (vla-get-name w) _sheet)
           (setq _ws w)
     (if
       (and (or _ws (setq _ws (last _tbs)))
         (setq _cells (vlax-get _ws 'cells))
       (foreach x _lst
         (apply
           (function vlax-put-property)
           (append (list _cells 'item) x)
     (vlax-invoke _ofile 'Save)
     (and flag (vlax-invoke _ofile 'close)
       (vlax-release-object _excelapp)
(defun getexcel ( _file _sheet flag / _excelapp _workbooks _ws _tbs _cc _l )
 (if
   (and
     (setq _file (findfile _file))
     (setq _ofile (vlax-invoke-method _workbooks "Open" _file))
       (cond
           (setq _ws w)
     (if (or _ws (setq _ws (last _tbs)))
         (setq _cc
           (vlax-get
             (vlax-get (vlax-get _ws 'UsedRange)
               'Columns
             ) 'Count
         )(setq _n 0)
           (lambda ( / _v _tmpl )
             (vlax-for x (vlax-get _ws 'UsedRange)
               (setq _v (vlax-get x 'value))
               (cond
                 ( (not _v)(setq _v ""))
                 ( (numberp _v)(setq _v (rtos _v 2)))
               )(setq _tmpl (cons _v _tmpl))
               (if (<= _cc (setq _n (1+ _n)))
                   (setq _l (cons (reverse _tmpl) _l))
                   (setq _tmpl nil _n 0)
         (and flag (vlax-invoke _ofile 'Close :vlax-false)
 ) (reverse _l)
USE
(putexcel "c:\\temp\\test.xls"
 (list
   (list 1 1 "Lt Dan's Legs")
   (list 6 2 "is the man!")
   (list 7 2 ":P")
 ) t
