the same text style uses different fonts in host and xref when viewd in host
samifox
hi
if i open the xref as a drawing i can see it using text style that use font A .
if i open the host drawing i can see that xref>style>font using different font.
how is that possible?
We can only guess without the files (hint) and here is mine.
The style is calling for a font that you don't have and a different substitute has been assigned in each file.
there is no reason why the font cannot be found. i can see two kind of font at the same time if i swithe btween the host and the xref. also the xref style is not listed in the host.
download
It's great that you were able to upload the entire files but because there is so much stuff in them, now we need to know what style and where we can see an example of it.
i've download it and its all there. the text style name is 5mm
thanks
Sorry, I can't be of any assistance. I do not have that font installed and I do not have permission to install it.
you really dont need to install the fonts.......all data is in the dwg
