Wiring Riser block
Ski_Me
I got this block I use for my wiring riser. Most of the time the devices are on the left side of the panel but some times if the job is big enough I will draw device on both sides of the panel. Problem is I need the line that is coming from the block to be on the other side. I did a rotation action on the line but it doesn't connect on the other side as you can see. I tried to figure something out in the block editor but couldn't get it to work. I thought I could detach from one side of the block and move the line to the other side of the block. Anybody have any ideas?
RISERBLOCKS.dwg
