Rotating list !؟
mstb
Hello every body
I have a list like this    (a b c d e f g h i j)
And I have 2 member of list like c and f   or h and b.
now  for example I want (c d e f)    for c and f
And I want (h i j a b)    for h and b
Thanks all.
What are a b c ...., variables, letters?
Use the (subst) function
(subst newitem olditem list)
(setq lst '("a" "b" "c" "d" "e" "f" "g" "h" "i" "j"))
(subst '("h" "i" "j" "a" "b") "b" lst)==> ("a" ("h" "i" "j" "a" "b") "c" "d" "e" "f" "g" "h" "i" "j")
(foreach pr (list '("b" ("h" "i" "j" "a" "b")) '("h" ("h" "i" "j" "a" "b")) '("c" ("c" "d" "e" "f")) '("f" ("c" "d" "e" "f")))
  (setq lst (subst (cadr pr) (car pr) lst))
The description is not 100% clear. But I think the OP wants a portion of the list defined by a start and end item, where the list must be considered circular. The solution below assumes that list items are unique.
; (get-sublist '("a" "b" "c" "d" "e" "f" "g" "h" "i" "j") "c" "f") => ("c" "d" "e" "f")
; (get-sublist '("a" "b" "c" "d" "e" "f" "g" "h" "i" "j") "h" "b") => ("h" "i" "j" "a" "b")
(defun get-sublist (lst sta end / tmpA tmpB)
  (cond
    ((not (setq tmpA (member sta lst)))
      nil
    ((reverse (member end (reverse tmpA)))) ; End after sta.
    ((setq tmpB (member end (reverse lst))) ; Sta after end.
      (append tmpA (reverse tmpB))
Edited by Roy_043
  (cond
      nil
Thanks . These are points .
I want to measure part of the sides of a parcel . not All.
So I need part of the points list.
Here's another variation -
(defun sub ( a b l / r )
    (if (vl-some '(lambda ( x ) (setq r (cons x r)) (= x b)) (member a (append l l)))
        (reverse r)
_$ (sub "c" "f" '("a" "b" "c" "d" "e" "f" "g" "h" "i" "j"))
("c" "d" "e" "f")
_$ (sub "h" "b" '("a" "b" "c" "d" "e" "f" "g" "h" "i" "j"))
Duplicates in the list will be a pain to deal with.
(setq lst '(a i c d i e f i g h))
;; Can't have your function return '(f i g h a i) by calling (fnc lst 'f 'i)
        (reverse r)
("c" "d" "e" "f")
Thank you very much
Quote
("c" "d" "e" "f")
Is that the result you're looking for mstb?
No , unfortunately It doesn't work for me.
my list includes polygon vertices .
  (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car (entsel))))))
  (setq p1 (getpoint "Select first point on the polygon")
    p2 (getpoint "Select second point on the polygon"))
Edited by mstb
HI  ALL
First, find the position of the first point of the list
(setq lst-pt    (mapcar (function cdr)
                          (vl-remove-if-not (function (lambda (a) (= (car a) 10))) (entget en))
                  ) ;_  mapcar
        lst-bulge (mapcar (function cdr)
                          (vl-remove-if-not (function (lambda (a) (= (car a) 42))) (entget en))
                  ) ;_  mapcar
	(setq X (CAR P1))
	(setq XX (CADR P1))
	(setq XS (mapcar 'cAr lst-pt))
	(setq XXS(mapcar 'cADr lst-pt))
	(setq iPP -1)
	(setq POISTION-2 (CAR(vl-remove nil (mapcar '(lambda ( XY y ) (setq iPP (1+ iPP)) (if (AND(= (RTOS X 2 2) (RTOS XY 2 2)) (= (RTOS XX 2 2) (RTOS Y 2 2))) iPP)) XS XXS))))
Then make a list rotation from the first point
;;https://www.cadtutor.net/forum/topic/62310-split-one-list-to-quotonequot-list/?fbclid=IwAR3OMb0erY3RkMObq7GH-UDXUWOgxLnAih9jTyzZrMeLEmUTsY3cR-se7Ro
(defun foo ( n Lst )
 (append
   (vl-member-if '(lambda (x) (= n x)) Lst)
   (reverse (cdr (vl-member-if '(lambda (x) (= n x)) (reverse Lst))))
_$ (foo 3 '(1 5 3 6 8 2 10))
(3 6 8 2 10 1 5)
_$
Second, find the position of the Second point of the  New list
Then  ;; (sublst '(1 2 3 4 5 6) 3 2) -> (0 position of the Second point )
;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/split-a-list-in-parts/td-p/1923656
    ;; Examples:
;; (sublst '(1 2 3 4 5 6) 3 2) -> (3 4)
;; (sublst '(1 2 3 4 5 6) 3 nil) -> (3 4 5 6)
(defun sublst (lst start leng / rslt)
(if (not (<= 1 leng (- (length lst) start)))
(setq leng (- (length lst) (1- start)))
(repeat leng
(setq rslt (cons (nth (1- start) lst) rslt)
start (1+ start)
(reverse rslt)
If I understand correct you have a pline/polygon with vertices pick pt1 on a vertice, pick point 2 on a  adjacent vertice, you can get simply by going through the vertices matching xy and you can get vertice number, so would be easy to make the correct new list of all vertices with pt1 as starting the only thing is wether a reverse is needed for Clockwise anticlockwise pline. The starting number would then be automatic.
vertices (1 2 3 4 5 6) ignore xyz for now
pick 3 4
so (3 4 5 6 1 2)
