  1. Today
  2. Thank you all. When I found the LM solution I abandoned the post...
  3. That isn't complete code it's just a layout of what to do. You had a function in your original post that had that function. -edit You can see this post to pull cords from an polyline without its own function https://www.cadtutor.net/forum/topic/76319-add-block-onto-polyline-vertices/#findComment-603350
  4. Hi mhupp. Thanks for the code , but I use Zwcad and get this Error: undefined function - GETCOORDS Thanks
  5. bustr
    Dimension Text Size Inconsistent.
    Thanks. I found a work-around. Not sure what caused it.
  6. Get you going on what StevenP and BigAL are talking about. (defun _option1 (/ SS SSPTZ SSVER PL1 PL2 PTlst1 PTlst2) (princ "\nSelect Base Polyline: ") (setq SS (ssget "_+.:E:S" '((0 . "LWPOLYLINE"))) ;emulates entselect only allowing you to select one entity at a time. PL1 (ssname ss 0) ) (princ "\nSelect Polyline to Check against: ") (setq SS (ssget "_+.:E:S" '((0 . "LWPOLYLINE"))) PL2 (ssname ss 0) ) (if (and PL1 PL2) ; if both polylines are selected build cords (setq PTLST1 (getcoords PL1) PTLST2 (getcoords PL2) ) (progn ;else prompt the user and rerun the command. (prompt "\nyou need to Select two Polylines for this command") (_option1) (exit) ) ) (foreach PT PTLST1 ;insert polyline block with "*" infront this will explode into a polyline ;add polylione to selection set SSVER ) (foreach PT PTLST2 ;add point to each vertex ;add point to SSPTZ selection set ) (foreach check SSVER ;use getcoords on Polyline and save as checkpts ;feed that into (ssget "_WP" checkpts '((0 . "POINT"))) ;check if only 1 point is found ;if yes delete polyline and point ;if no skip polyline ) (if (> (sslength SSPTZ) 0) ;points left are outside fuzz distance between poly1 and poly2 vertex (foreach PT SSPTZ ;delete pt and grdraw X at location ) ) (if (> (sslength SSVER) 0) ;if any polylnes are left a point wasn't found inside it. (progn (setq f (sslength SSVER)) (prompt (strcat "\n " f "Fertex(s) found on poly1 not matching Poly2") ) ) (princ "\nCheck Complete !!.") (princ) )
  7. SLW210
    You will need to post the .dwg.
  8. One step further could be to increase or decrease the size of the MTEXT objects. This could be done dynamically, giving meaning to the cursor movement: when it moves in a certain direction, it not only determines the justification but also, as it moves farther away, it gradually increases the size step by step. In my opinion, this is an interesting idea that deserves to be explored.
  9. Thanks @BIGAL working fine now.
  10. Not sure why the code was posted that way 2 typos. (defun c:ellpl ( / lwpoly obj oldsnap num inc dist plst pt) (defun LWPoly (lst cls) (entmakex (append (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbPolyline") (cons 90 (length lst)) (cons 70 cls)) (mapcar (function (lambda (p) (cons 10 p))) lst)))) (setq obj (vlax-ename->vla-object (car (entsel "\nPick ellipse ")))) (setq oldsnap (getvar 'osmode)) (setvar 'osmode 0) (setq num 100) (setq inc (/ (vlax-curve-getdistatparam obj (vlax-curve-getendparam obj)) num) dist 0.0 plst '() ) (repeat (+ num 1) (setq pt (vlax-curve-getpointatdist obj dist)) (setq plst (cons pt plst)) (setq dist (+ dist Inc)) ) (LWPoly plst 1) (setvar 'osmode oldsnap ) (princ) )
  11. @CivilTechSource It's easy to do that. I have make a more robust filter for mtext (with your exemple, adjust if necessary) (defun q_ang (alpha / ) (cond ((not (eq (rem alpha (* 1.5 pi)) alpha)) 4) ((not (eq (rem alpha pi) alpha)) 3) ((not (eq (rem alpha (* 0.5 pi)) alpha)) 2) (T 1) ) ) (defun c:wow ( / ss ent dxf_ent ptlst n pt_cen dir_ang tmp ofst n rot) (princ "\nSelect closed polylines") (setq ss (ssget "_+.:E:S" '((0 . "LWPOLYLINE") (90 . 4) (-4 . "&") (70 . 1)))) (cond (ss (initget 4) (setq ent (ssname ss 0) dxf_ent (entget ent) ptlst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) dxf_ent)) n (float (length ptlst)) pt_cen (list (/ (apply '+ (mapcar 'car ptlst)) n) (/ (apply '+ (mapcar 'cadr ptlst)) n)) dir_ang (mapcar 'q_ang (mapcar '(lambda (x) (angle pt_cen x)) ptlst)) tmp (* (distance pt_cen (car ptlst)) 0.25) ofst (getdist (car ptlst) (strcat "\nOffset for text <" (rtos (getvar "TEXTSIZE")) ">?: ")) ) (if (not ofst) (setq ofst (getvar "TEXTSIZE"))) (mapcar '(lambda (p d / j po) (setq qsel (ssget "_C" (mapcar '- p (list tmp tmp 0.0)) (mapcar '+ p (list tmp tmp 0.0)) '((0 . "MTEXT") (8 . "-LE-E-External Levels") (7 . "LE Standard (No Height)")))) (cond (qsel (repeat (setq n (sslength qsel)) (setq ent (ssname qsel (setq n (1- n))) dxf_ent (entget ent) rot (cdr (assoc 50 dxf_ent)) ) (if (eq d 1) (if (zerop rot) (setq j 9 po (polar p (* 0.5 pi) ofst)) (setq j 7 po (polar p 0.0 ofst)))) (if (eq d 2) (if (zerop rot) (setq j 7 po (polar p (* 0.5 pi) ofst)) (setq j 1 po (polar p pi ofst)))) (if (eq d 3) (if (zerop rot) (setq j 1 po (polar p (* 1.5 pi) ofst)) (setq j 7 po (polar p pi ofst)))) (if (eq d 4) (if (zerop rot) (setq j 3 po (polar p (* 1.5 pi) ofst)) (setq j 1 po (polar p 0.0 ofst)))) (setq dxf_ent (subst (cons 10 po) (assoc 10 dxf_ent) dxf_ent)) (setq dxf_ent (subst (cons 71 j) (assoc 71 dxf_ent) dxf_ent)) (entmod dxf_ent) ) ) ) ) ptlst dir_ang ) ) ) (prin1) )
  12. I'm getting this error Command: ; error: malformed list on input I also found this online. but it's converting the ellipse into full circle. This is working fine before. ;Tip1539A: EL2PL.LSP Ellipse to Pline (c)1999, Oleg Khenson (defun C:EL2PL (/ A CEN CLA CMD DIS EN END_P1 END_P2 ENT I K LA LT M MINOR% NM OLDERR OS PELMODE SS ) (defun DXF (CODE ELIST) (cdr (assoc CODE ELIST))) (defun EL2PL_ERR (S) (if (/= S "Function cancelled") (princ (strcat "\nError: " S)) ) (setvar "CMDECHO" CMD) (if OS (setvar "OSMODE" OS) ) (setq *ERROR* OLDERR OLDERR NIL ) (princ) ) (setq OLDERR *ERROR* *ERROR* EL2PL_ERR ) (setq CMD (getvar "CMDECHO")) (setvar "CMDECHO" 0) (princ "\nSelect Ellipses to be converted to PLines: ") (setq SS (ssget '((0 . "ELLIPSE")))) (command ".UNDO" "G") (if SS (progn (setq OS (getvar "OSMODE")) (setvar "OSMODE" 0) (setq I 0 K 0 M 0 ) (repeat (sslength SS) ; for each entity from SS (setq A (entget (setq NM (ssname SS I) ENT NM ) ) LA (DXF 8 A) ) (if (< (cdr (assoc 70 (tblsearch "LAYER" LA))) 4) (progn (if (= (DXF 0 A) "ELLIPSE") (progn (setq LT (DXF 6 A) CEN (DXF 10 A) MINOR% (DXF 40 A) END_P1 (mapcar '+ CEN (DXF 11 A)) DIS (distance CEN END_P1) END_P2 (polar CEN (+ (angle CEN END_P1) (/ pi 2.0)) (* DIS MINOR%) ) ) (setq PELMODE (getvar "PELLIPSE")) (setvar "PELLIPSE" 1) (setq CLA (getvar "CLAYER")) (if (/= CLA LA) (setvar "CLAYER" LA) ) (command ".ELLIPSE" "C" (trans CEN 0 1) (trans END_P1 0 1) (trans END_P2 0 1) ) (setq K (1+ K)) (setvar "PELLIPSE" PELMODE) (entdel ENT) (if (/= CLA (getvar "CLAYER")) (setvar "CLAYER" CLA) ) (if (and LT (/= (DXF 6 (tblsearch "LAYER" LA)) LT) ) (progn (command ".CHPROP" "L" "" "LT" LT "") (command ".PEDIT" "L" "L" "ON" "") ) ) ) ) ) (setq M (1+ M)) ) (setq I (1+ I)) ) (if (> M 0) (princ (strcat "\n" (itoa M) (if (= M 1) " ELLIPSE was" " ELLIPSEs were" ) " on locked layer" (if (= M 1) "." "(s)." ) ) ) ) (if (> K 0) (princ (strcat "\n" (itoa K) " ELLIPSE" (if (= K 1) " was" "s were" ) " successfully converted to PLINE" (if (= K 1) "." "s." ) ) ) ) ) ) (setq *ERROR* OLDERR) (command ".UNDO" "E") (if OS (setvar "OSMODE" OS) ) (setvar "CMDECHO" CMD) (princ) )
  13. Yesterday
  14. @Tsuky (/ (* 3 pi) 2) (* 1.5 pi) (* 0.25 pi) and so on. @CivilTechSource have you looked at my Multi getvals.lsp it will make a dcl on the fly for you for input of offset values, can set defaults . Look in downloads.
  15. Just throwing ideas around, take the base Pline, get vertices then search for objects withing a polygon shape say 8 sides, then compare points find a point within say the desired tolerance and move that point within the other pline. In dwg can see two plines at one location so like @Steven P need a loop to check more than 1 pline meeting at a point. Then pick another base pline and repeat. No time for coding the next few days.
  16. I suppose the next to improve it is add offset, or a settings menu?
  17. I haven't had chance to look through this fully, but it looks like you have a few loops in there - with more and more polylines it might star to really slow down. Interesting problem to think about maybe tomorrow
  18. Hi , I want to do some updates to this code because is not working as i expeted. The option1 check the vertex between 2 polylines and visualised the vertex with not mach. I want the option1 to work for more than 2 polylines. The option 2 adjust the base polyline with one more , but i want to adjust only the problematic vertex not all (some times move more than the problematic vertex). I was thinking to export a file with the problematic vertex and then adjust the problematic vertex from file with the base polyline. I want to adjust more than one polyline a time . ;Help from marko_ribar in older post ; https://www.cadtutor.net/forum/topic/95097-adjust-polyline-sides/ (defun c:pladj (/ *error* dch dcl msg des drv _option1 _option2) ; -----option1--------- (defun _option1 (/ ss pl1 pl2 pl:lst1 pl:lst2 unmatched1 unmatched2 pt1 pt2 x_size fuzz) ;; Define size of the "X" (length of each line segment) (setq x_size 1.0) ; Adjust this value to make the "X" larger or smaller (setq fuzz 1.0) ; Acceptable distance to consider vertices "close" ;; Create selection set and ensure two polylines are selected (setq ss (ssadd)) (while (not (= (sslength ss) 2)) (princ "\nSelect base Polyline: ") (setq ss (ssget (list (cons 0 "LWPOLYLINE")))) (if (not (= (sslength ss) 2)) (princ "\nSelect other polylines to check") ) ) ;; Get the two polylines (setq pl1 (ssname ss 0) pl2 (ssname ss 1) pl:lst1 (getcoords pl1) pl:lst2 (getcoords pl2) unmatched1 '() unmatched2 '() ) ;; Collect unmatched vertices from pl1 (foreach a pl:lst1 (if (not (member a pl:lst2)) (setq unmatched1 (cons a unmatched1)) ) ) ;; Collect unmatched vertices from pl2 (foreach a pl:lst2 (if (not (member a pl:lst1)) (setq unmatched2 (cons a unmatched2)) ) ) ;; Compare all unmatched pairs and draw Xs if they are close (foreach pt1 unmatched1 (foreach pt2 unmatched2 (if (<= (distance pt1 pt2) fuzz) (progn ;; Draw X at pt1 (color 140) (grdraw (list (- (car pt1) x_size) (- (cadr pt1) x_size) 0.0) (list (+ (car pt1) x_size) (+ (cadr pt1) x_size) 0.0) 140 0 ) (grdraw (list (- (car pt1) x_size) (+ (cadr pt1) x_size) 0.0) (list (+ (car pt1) x_size) (- (cadr pt1) x_size) 0.0) 140 0 ) ;; Draw X at pt2 (color 10) (grdraw (list (- (car pt2) x_size) (- (cadr pt2) x_size) 0.0) (list (+ (car pt2) x_size) (+ (cadr pt2) x_size) 0.0) 10 0 ) (grdraw (list (- (car pt2) x_size) (+ (cadr pt2) x_size) 0.0) (list (+ (car pt2) x_size) (- (cadr pt2) x_size) 0.0) 10 0 ) ) ) ) ) (princ "\nThe check comlete !!.") (princ) ) (defun getcoords (ent / lst1 lst2) (setq lst1 (vlax-safearray->list (vlax-variant-value (vlax-get-property (vlax-ename->vla-object ent) "Coordinates")))) (setq lst2 '()) (while lst1 (setq lst2 (append lst2 (list (list (car lst1) (cadr lst1))))) (setq lst1 (cddr lst1)) ) lst2 ) ; -----option2--------- (defun _option2 ( / vertlst unique lwupd lw1 lw2 enx1 enx fuzz vl1 vl2 bl par ) (or (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-get-acad-object) nil))) (vl-load-com)) (defun vertlst ( lw / enx ) (mapcar (function (lambda ( p ) (append (mapcar (function +) (list 0.0 0.0) (trans p lw 0)) (list (cdr (assoc 38 enx))) ) ) ) (mapcar (function cdr) (vl-remove-if (function (lambda ( x ) (/= (car x) 10) ) ) (setq enx (entget lw)) ) ) ) ) (defun unique ( lst fuzz / a ll ) (while (setq a (car lst)) (if (vl-some (function (lambda ( x ) (equal x a fuzz))) (cdr lst)) (setq ll (cons a ll) lst (vl-remove-if (function (lambda ( x ) (equal x a fuzz))) (cdr lst))) (setq ll (cons a ll) lst (cdr lst)) ) ) (reverse ll) ) (defun lwupd nil (setq enx (subst (cons 38 (caddar vl2)) (assoc 38 enx) enx)) (setq enx (subst (cons 90 (length vl2)) (assoc 90 enx) enx)) (setq enx (append (reverse (cdr (member (assoc 10 enx) (reverse enx)) ) ) (mapcar (function (lambda ( p ) (cons 10 (trans p 0 lw2)) ) ) vl2 ) (list (assoc 210 enx)) ) ) (entupd (cdr (assoc -1 (entmod enx)))) ) (if (and (setq lw1 (car (entsel "\nSelect Base LWPOLYLINE ..."))) (= (cdr (assoc 0 (setq enx1 (entget lw1)))) "LWPOLYLINE") (vl-every (function (lambda ( x ) (= (cdr x) 0.0))) (vl-remove-if (function (lambda ( x ) (/= (car x) 42))) enx1)) (setq lw2 (car (entsel "\nSelect LWPOLYLINE you want to adjust..."))) (= (cdr (assoc 0 (setq enx (entget lw2)))) "LWPOLYLINE") (vl-every (function (lambda ( x ) (= (cdr x) 0.0))) (vl-remove-if (function (lambda ( x ) (/= (car x) 42))) enx)) (princ "\nAnnotation (m) : ") (not (initget 6)) (setq fuzz (cond ( (getdist) ) ( 1.0 ))) ) (progn (setq vl1 (vertlst lw1)) (setq vl2 (vertlst lw2)) (setq vl2 (unique vl2 (* fuzz 0.5))) (foreach v1 vl1 (foreach v2 vl2 (if (<= (distance v1 v2) fuzz) (setq vl2 (mapcar (function (lambda ( x ) (if (equal x v2 (* fuzz 1e-12)) v1 x) ) ) vl2 ) ) ) ) ) (setq vl2 (unique vl2 (* fuzz 0.5))) (foreach v vl1 (if (and (not (vl-position v vl2)) (<= (distance v (vlax-curve-getclosestpointto lw2 v)) fuzz) (setq par (vlax-curve-getparamatpoint lw2 (vlax-curve-getclosestpointto lw2 v))) ) (setq vl2 (append (reverse (member (nth (fix par) vl2) (reverse vl2)) ) (list v) (member (nth (1+ (fix par)) vl2) vl2) ) ) ) ) ;| (mapcar (function (lambda ( a b c ) (if (equal (distance a c) (+ (distance a b) (distance b c)) (* fuzz 5e-5)) (setq bl (cons b bl)) ) ) ) vl2 (append (cdr vl2) (list (car vl2))) (append (cddr vl2) (list (car vl2) (cadr vl2))) ) (foreach b (unique bl (* fuzz 1e-12)) (setq vl2 (vl-remove b vl2)) ) |; (setq vl2 (unique vl2 (* fuzz 0.5))) (foreach v vl1 (lwupd) (if (and (not (vl-position v vl2)) (vl-some (function (lambda ( x ) (<= (distance x v) fuzz) ) ) vl2 ) (vl-some (function (lambda ( a b ) (equal (distance a b) (+ (distance a v) (distance v b)) (* fuzz 1e-3)) ) ) vl2 (append (cdr vl2) (list (car vl2))) ) (setq par (vlax-curve-getparamatpoint lw2 (vlax-curve-getclosestpointto lw2 v))) ) (setq vl2 (append (reverse (member (nth (fix par) vl2) (reverse vl2)) ) (list v) (member (nth (1+ (fix par)) vl2) vl2) ) ) ) ) (lwupd) ) ) (princ) ) ;-------------------------------DCL MENU------------------------------------------------------------------------------------ (defun *error* (msg) (if (and (= 'int (type dch)) (< 0 dch))(unload_dialog dch)) (if (= 'file (type des))(close des)) (if (and (= 'str (type dcl)) (findfile dcl))(vl-file-delete dcl)) (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))) (princ (strcat "\nError: " msg))) (princ) ) (setvar "OSMODE" 13) (if (not (and (setq dcl (vl-filename-mktemp nil nil ".dcl"))(setq des (open dcl "w")))) (princ "\nUnable to open DCL for writing.") (foreach str '( "ed : edit_box { alignment = left; width = 25; edit_width = 10; fixed_width = true;}" "" "pladj : dialog { spacer; key = \"dcl\";" " : boxed_radio_column {label = \"Select \";" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button01\"; label = \"1. Check Polylines\";" " }" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button02\"; label = \"2. Adjust Polylines\";" " }" " }" " ok_only;" "}" ) (write-line str des) ) ;;; end foreach ) ;;; end if (if des (progn (close des)(gc))) (if (and (setq dch (load_dialog dcl)) (new_dialog "pladj" dch)) (progn (set_tile "dcl" "Adjust Polyline") (action_tile "radio_button01" "(setq sng 1)") (action_tile "radio_button02" "(setq sng 2)") (action_tile "accept" "(done_dialog 1)") (action_tile "cancel" "(done_dialog 0)") ;;; dialog return value (setq drv (start_dialog)) ;;; once loaded , get rid of temp dcl file (if (and dcl (findfile dcl))(vl-file-delete (findfile dcl))) (cond ((= drv 0)) ((= drv 1) (cond ((= sng 1)(_Option1)) ((= sng 2)(_Option2)) ) ) ) ) ) (princ) ) Thanks test.dwg
  19. Clearly there are two different sizes of dimension text shown here but in the properties box they are both shown to be .125" in height. Can anyone tell me how to force the correct size on existing dimension text?
  20. @Tamim Did this help?
  21. For a start, my 2 cents... (defun q_ang (alpha / ) (cond ((not (eq (rem alpha (/ (* 3 pi) 2)) alpha)) 4) ((not (eq (rem alpha pi) alpha)) 3) ((not (eq (rem alpha (/ pi 2)) alpha)) 2) (T 1) ) ) (defun c:wow ( / ss ent dxf_ent ptlst n pt_cen dir_ang tmp n rot) (princ "\nSelect closed polylines") (setq ss (ssget "_+.:E:S" '((0 . "LWPOLYLINE") (90 . 4) (-4 . "&") (70 . 1)))) (cond (ss (setq ent (ssname ss 0) dxf_ent (entget ent) ptlst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) dxf_ent)) n (float (length ptlst)) pt_cen (list (/ (apply '+ (mapcar 'car ptlst)) n) (/ (apply '+ (mapcar 'cadr ptlst)) n)) dir_ang (mapcar 'q_ang (mapcar '(lambda (x) (angle pt_cen x)) ptlst)) tmp (* (distance pt_cen (car ptlst)) 0.25) ) (mapcar '(lambda (p d / j) (setq qsel (ssget "_C" (mapcar '- p (list tmp tmp 0.0)) (mapcar '+ p (list tmp tmp 0.0)) '((0 . "MTEXT")))) (repeat (setq n (sslength qsel)) (setq ent (ssname qsel (setq n (1- n))) dxf_ent (entget ent) rot (cdr (assoc 50 dxf_ent)) ) (if (eq d 1) (if (zerop rot) (setq j 9) (setq j 7))) (if (eq d 2) (if (zerop rot) (setq j 7) (setq j 1))) (if (eq d 3) (if (zerop rot) (setq j 1) (setq j 7))) (if (eq d 4) (if (zerop rot) (setq j 3) (setq j 1))) (setq dxf_ent (subst (cons 10 p) (assoc 10 dxf_ent) dxf_ent)) (setq dxf_ent (subst (cons 71 j) (assoc 71 dxf_ent) dxf_ent)) (entmod dxf_ent) ) ) ptlst dir_ang ) ) ) (prin1) )
  22. As @BIGAL says, I think Claude is suggesting you unnecessary code. I've modified my previous code to create a loop. I've also simplified and fixed a small loophole in the logic of the 'DefMTextJustification' function. (defun c:LE-CalExtFFL ( / pt1 pt2 pt3 r TxtRotation TxtJustification radians degrees ecoA para) (setq ecoA (getvar "CMDECHO")) (setvar "CMDECHO" 0) (vla-startUndomark (vla-get-activeDocument (vlax-get-acad-object))) (command "_layer" "_m" "-LE-E-External Levels" "") (setq Prefix "") (setq Suffix "") (while (and (not para) (setq ffl-ent (car (entsel))) (= (cdr (assoc 0 (entget ffl-ent))) "MTEXT") ) (if (setq r (vl-catch-all-apply '(lambda () ;; Get the MText object and extract text content (setq ffl-obj (entget ffl-ent)) (setq ffl-text (cdr (assoc 1 ffl-obj))) (princ (strcat "\nFFL Text found: " ffl-text)) (setq ffl-value (ExtractFFLValue ffl-text)) (princ "\nSelect points where to place the level text (Press Enter to finish): ") (if ffl-value (if (setq pt1 (getpoint "\nSelect first point: ")) (if (setq pt2 (getpoint pt1 "\nSelect second point: ")) (virtualiza) ) ) ) ) ) ) (setq para T) ) ) (if r (entdel (entlast))) (setvar "CMDECHO" ecoA) (princ) ) (defun asr (p1 p2 p3 / a b) (if (> (abs (- (setq a (angle p1 p2)) (setq b (angle p2 p3)))) PI) (if (< a b) (if (> (+ a PI PI) b) - +) (if (> (- a PI PI) b) - +) ) (if (> a b) - +) ) ) (defun virtualiza (/ para grd mto) (princ "\nMove the mouse to decide justification (escape to CANCEL)...") (while (and (not para) (setq grd (grread nil 13 0)) (listp (cadr grd))) (setq pt3 (cadr grd)) (setq SpotLevel (- ffl-value 0.15)) ;; Initialize point list ;; Prompt for points where to place the new MText (setq TxtRotation (angle pt1 pt2)) (setq TxtValue SpotLevel) (DefMTextJustification pt1 pt2 pt3) (if mto (entmod (subst (cons 71 TxtJustification) (assoc 71 (entget mto)) (entget mto))) (setq mto (CreateMText pt1 TxtValue TxtRotation TxtJustification) ) ) (if (= (car grd) 3) (setq para T)) ) (vla-EndUndomark (vla-get-activeDocument (vlax-get-acad-object))) ) (defun ExtractFFLValue (text-string / clean-text) (if (> (strlen text-string) 5) ;Charcters Removed from String (setq clean-text (substr text-string 6)) (setq clean-text text-string) ) (if (numberp (read clean-text)) (read clean-text) (progn (vlr-beep-reaction) (princ "\n*** ERROR : Could not extract numeric value from FFL text ***") nil ) ) ) (defun DefMTextJustification ( p1 p2 p3 / ) ;; Top Left = 1 ;; Top Center = 2 ;; Top Right = 3 ;; Middle Left = 4 ;; Middle Center = 5 ;; Middle Right = 6 ;; Bottom Left = 7 ;; Bottom Center = 8 ;; Bottom Right = 9 (if (or (and (>= (angle p1 p2) 0.0) (<= (angle p1 p2) (/ PI 2.))) (>= (angle p1 p2) (/ (* 3. PI) 2.)) ) (progn (setq Prefix "+") (setq Suffix "") (if (= (asr p1 (inters p1 p2 p3 (polar p3 (+ (angle p1 p2) (/ PI 2.)) 1) nil) p3) -) (setq TxtJustification 1) (setq TxtJustification 7) ) ) (progn (setq Prefix "") (setq Suffix "+") (setq TxtRotation (+ TxtRotation pi)) (if (= (asr p1 (inters p1 p2 p3 (polar p3 (+ (angle p1 p2) (/ PI 2.)) 1) nil) p3) +) (setq TxtJustification 3) (setq TxtJustification 9) ) ) ) ) (defun CreateMText ( point txtvalue txtrot txtjust / txtjust txtrot mtext-obj) (setq mtext-obj (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 8 (getvar "CLAYER")) ; Current layer (cons 100 "AcDbMText") (cons 10 point) ; Insertion point (cons 40 0.5) ; Text height (adjust as needed) (cons 41 0.0) ; Reference rectangle width (cons 71 txtjust) (cons 72 5) ; Drawing direction (cons 1 (strcat Prefix (rtos txtvalue 2 3) Suffix)) ; Text content with "+" prefix (cons 50 txtrot) ; Rotation angle ) ) ) mtext-obj )
  23. 4 Attribute Block is better.. thanks !
  24. Last week
  25. Maybe you miss understood my comment, PI is an inbuilt function (princ pi) type it, so you can have the other angles as just ( / pi 2.) and so on. You don't need to declare it.
  26. In the sort routine I have it just sorts based on the attribute order, so just need to change that in the list made prior to sorting. Wiil see what I can do. One issue is that the code would be written for a 4 Attribute block, so if you have say a different block say a 3 attribute it would not work.
  27. @GLAVCVS The visualisation is so awesome! I managed (with some Claude help) to make it work with your suggestion and have it looped! I think the software no is perfect? OR there is still room for improvement??/ ;; LE-CalExtFFL - Calculate External Finished Floor Level ;; Improved version with better error handling and structure (defun c:LE-CalcExtFFL ( / ffl-ent ffl-obj ffl-text ffl-value spot-level pt1 pt2 pt3 txt-rotation txt-justification prefix suffix pi continue-loop placement-count) ;; Constants (setq pi 3.141592653589793) ;; Initialize variables (setq prefix "" suffix "" txt-justification 1 txt-rotation 0.0 continue-loop T placement-count 0) ;; Set layer (if (not (SetWorkingLayer "-LE-E-External Levels")) (progn (princ "\nError: Could not create or set layer.") (exit) ) ) ;; Get FFL reference text (only once) (setq ffl-value (GetFFLReference)) (if (not ffl-value) (progn (princ "\nOperation cancelled or invalid FFL selected.") (exit) ) ) ;; Calculate spot level (FFL - 0.15) (setq spot-level (- ffl-value 0.15)) (princ (strcat "\nFFL Value: " (rtos ffl-value 2 3))) (princ (strcat "\nCalculated spot level: " (rtos spot-level 2 3))) ;; Main placement loop - continues until user exits (princ "\n" ) (princ "\n========================================") (princ "\nPlace level markers using 3-point method") (princ "\nPress ESC or Enter at any prompt to finish") (princ "\n========================================") (while continue-loop (princ (strcat "\n\nMarker #" (itoa (1+ placement-count)) ":")) (setq pt1 (getpoint "\nSelect first point (text location): ")) (if pt1 (progn (setq pt2 (getpoint pt1 "\nSelect second point (direction): ")) (if pt2 (progn (virtualiza) ; Function to select third point and visualize ) (progn (princ "\nPlacement cancelled.") (setq continue-loop nil) ; User cancelled pt2 ) ) ) (progn (setq continue-loop nil) ; User cancelled pt1 or pressed Enter ) ) ) (princ (strcat "\nCommand completed. " (itoa placement-count) " level markers created.")) (princ) ) ;; Function to set working layer (defun SetWorkingLayer (layer-name / ) (if (tblsearch "LAYER" layer-name) (progn (command "._layer" "_s" layer-name "") T ) (progn (command "._layer" "_m" layer-name "") (if (tblsearch "LAYER" layer-name) (progn (command "._layer" "_s" layer-name "") T ) nil ) ) ) ) ;; Function to get FFL reference value (defun GetFFLReference ( / ffl-ent ffl-obj ffl-text) (princ "\nSelect FFL reference text: ") (setq ffl-ent (car (entsel))) (cond ((not ffl-ent) (princ "\nNo entity selected.") nil ) ((not (= (cdr (assoc 0 (entget ffl-ent))) "MTEXT")) (princ "\nSelected entity is not MTEXT. Please select MTEXT containing FFL value.") nil ) (T (setq ffl-obj (entget ffl-ent) ffl-text (cdr (assoc 1 ffl-obj))) (princ (strcat "\nFFL Text found: " ffl-text)) (ExtractFFLValue ffl-text) ) ) ) ;; Improved FFL value extraction (defun ExtractFFLValue (text-string / clean-text numeric-value) (if (not text-string) (progn (princ "\nError: Empty text string.") nil ) (progn ;; Remove first 5 characters if string is long enough (if (> (strlen text-string) 5) (setq clean-text (substr text-string 6)) (setq clean-text text-string) ) ;; Try to extract numeric value (setq numeric-value (ExtractNumericFromString clean-text)) (if numeric-value (progn (princ (strcat "\nExtracted FFL value: " (rtos numeric-value 2 3))) numeric-value ) (progn (princ "\nError: Could not extract numeric value from FFL text.") (princ (strcat "\nProcessed text: '" clean-text "'")) nil ) ) ) ) ) ;; Extract numeric value from string (handles various formats) (defun ExtractNumericFromString (str / i char result decimal-found) (setq result "" decimal-found nil i 1) (while (<= i (strlen str)) (setq char (substr str i 1)) (cond ;; Numeric characters ((and (>= (ascii char) 48) (<= (ascii char) 57)) (setq result (strcat result char)) ) ;; Decimal point (only first one) ((and (= char ".") (not decimal-found)) (setq result (strcat result char) decimal-found T) ) ;; Negative sign (only at start) ((and (= char "-") (= i 1)) (setq result (strcat result char)) ) ) (setq i (1+ i)) ) (if (and (> (strlen result) 0) (numberp (read result))) (read result) nil ) ) ;; Set text justification and prefix/suffix based on geometry (defun SetTextJustificationAndFixes (p1 p2 p3 / angle12 angle13 pi) (setq pi 3.141592653589793 angle12 (angle p1 p2) angle13 (angle p1 p3)) ;; Normalize angles to 0-2π range (if (< angle12 0) (setq angle12 (+ angle12 (* 2 pi)))) (if (< angle13 0) (setq angle13 (+ angle13 (* 2 pi)))) (cond ;; Text direction is roughly horizontal (right-going) or vertical up ((or (and (>= angle12 0.0) (<= angle12 1.570796327)) ; 0° to 90° (>= angle12 4.712388980)) ; 270° to 360° (setq txt-justification 1 ; Top Left prefix "+" suffix "") ;; Check if reference point suggests bottom alignment (if (> angle13 angle12) (progn (setq txt-justification 7 ; Bottom Left prefix "+" suffix "") ;; Special case for horizontal line with reference below (if (and (< (abs angle12) 0.1) (> angle13 4.71238898)) (setq txt-justification 1 ; Back to Top Left prefix "+" suffix "") ) ) ) ) ;; Text direction is roughly horizontal (left-going) (T (setq txt-justification 3 ; Top Right prefix "" suffix "+" txt-rotation (+ txt-rotation pi)) ; Flip text 180° ;; Adjust justification based on reference point (if (> angle13 angle12) (setq txt-justification 3 ; Top Right prefix "" suffix "+") (setq txt-justification 9 ; Bottom Right prefix "" suffix "+") ) ) ) ) ;; Create MText entity with specified parameters (defun CreateLevelMText (point txt-value txt-rotation txt-justification prefix suffix / mtext-obj) (setq mtext-obj (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 8 (getvar "CLAYER")) ; Current layer (cons 62 256) ; Color by layer (cons 100 "AcDbMText") (cons 10 point) ; Insertion point (cons 40 0.5) ; Text height (cons 41 0.0) ; Reference rectangle width (cons 71 txt-justification) ; Attachment point (cons 72 5) ; Drawing direction (cons 1 (strcat prefix (rtos txt-value 2 2) suffix)) ; Text content (cons 50 txt-rotation) ; Rotation angle (cons 73 1) ; Line spacing style (cons 44 1.0) ; Line spacing factor ) ) ) (if mtext-obj T nil ) ) ;; Utility function to convert radians to degrees (for debugging) (defun RadiansToDegrees (radians) (* radians (/ 180.0 3.141592653589793)) ) (defun virtualiza (/ para grd mto) (princ "\nMove the mouse to decide justification (escape to CANCEL)...") (while (and (not para) (setq grd (grread nil 13 0)) (listp (cadr grd))) (setq pt3 (cadr grd)) (setq SpotLevel (- ffl-value 0.15)) ;; Initialize point list ;; Prompt for points where to place the new MText (setq TxtRotation (angle pt1 pt2)) (setq TxtValue SpotLevel) (DefMTextJustification pt1 pt2 pt3) (if mto (entmod (subst (cons 71 TxtJustification) (assoc 71 (entget mto)) (entget mto))) (setq mto (CreateMText pt1 TxtValue TxtRotation TxtJustification)) ) (if (= (car grd) 3) (setq para T)) ) (vla-EndUndomark (vla-get-activeDocument (vlax-get-acad-object))) ) ;; Print startup message (princ "\nLE-CalExtFFL command loaded. Type LE-CalExtFFL to run.") (princ)
  28. By my count, AutoCAD comes with 82 hatch patterns. A list that large will surely contain everything you need, right? Of course not. That’s where SuperHatch can come to the rescue. SuperHatch is an AutoLISP command, and can be found in the Draw panel of the Express Tools tab of the ribbon. It seems like it’s been there forever, but it has a copyright date of 1999 in the .LSP file, so we’ll go with that. SuperHatch allows you to use an image, block, Xref, or wipeout as a hatch pattern. Or, if one of those objects already exists in your drawing, you can simply select it. Let’s look at a couple of ways to use this Express Tool to your advantage. Apply Material Images Let’s say you have a 2D detail that’s just lines and polylines. The boss comes to you and tells you they need to use it for the marketing team, and tells you to “add a little pop with some realistic looking materials”? Oh, and they need it for a meeting in half an hour. Now what? You scroll through the gallery of hatches, and of course, nothing there comes close. You need a hatch pattern for wood, concrete, and dirt. There’s probably something in the Materials collection over in the 3D world, but that’s not a good option either. Then you remember that blog post you read about SuperHatch. Remember? You can apply images as hatches. Being a resourceful internet search engine user, you quickly find some great images and download them (or screengrab and save as an image). Now you at least have your images and you have about 20 minutes left. No problem. Let’s look at that workflow. I’ve inserted my three images in the image below using the Xref palette. A word of warning… if you did use a screencap method to grab your image, and are thinking of just popping it in, make sure you use “Paste Special” and add it as an “Image Entity”. Otherwise, you’ll get an OLE object and SuperHatch won’t know what to do with it. Since I’ve already added the images, I’ll call up SuperHatch and use the “Select existing <” button. I’ll select the wood grain image, then with the default option of “Internal Point”, I’ll click inside one of the upright rectangles, and then the other. Now that my internal picking is done, I’ll press Enter, and the wood grain hatch is created! Do the same workflow for the other two necessary images, filling in the footings and the surrounding dirt, and you’ve just made the boss happy with 15 minutes to spare. Go ahead and give yourself a pat on the back while you’re getting a well-deserved cup of coffee. Create Your Own Hatch-looking Hatch The file that contains the hatch pattern definitions is named acad.pat. If you find it and open it, you’ll see that it’s a simple text file containing a bunch of cryptic definitions. Scroll to the bottom to see a section designated for user-defined patterns. I bet yours is empty too. Nobody in their right mind is going to try their hand at creating a complicated hatch pattern. Check out the image below. These are the definitions for Hexagon and Honeycomb. Both are somewhat complicated, but not terrible. Unless you try to code it. But, you need what you need, and that’s a complex custom hatch pattern – or at least something that looks like a hatch pattern. SuperHatch to the rescue again. Check out the animation below. I’ve created a drawing that I want to use as a “tile” in my hatch design. This time, it’s sitting out in a folder, so I choose the “Block” option in the SuperHatch dialog, (yes, fellow Lispers – it’s a DCL file), navigate to my drawing, pop an instance of it into blank space, accept the insert defaults, and another return to end its selection. Now it works like our first example, where I select an interior point and again press return. And, just like that, I’ve created a hatch-looking hatch! Pretty slick, I’d say. One more thing… You can select the new faux hatch, but like I said, it’s not a real hatch object. It’s an unnamed Group. If you turn off Group Selection, you can select the individual blocks that make up the group. That control is found in the Home tab of the ribbon, within the Groups panel. A Final Thought Are there some nuances to using SuperHatch? Yes. You can’t adjust anything after you’re done. In my previous example, the block used was the same size as the one I chose. If I wanted it bigger, I would have had to scale it during insertion. With the materials images, size also matters. If you put them into the drawing like I did, you might want to make them big; otherwise, they too will want to tile and mess up your fake materials. But, if the situation calls for it, or even if it’s the boss, SuperHatch really can become your superhero. (Cape and mask not included.) More Tuesday Tips Check out our whole Tuesday Tips series for ideas on how to make AutoCAD work for you. The post Take a Ride on the Hatch Express With SuperHatch: Tuesday Tips With Frank appeared first on AutoCAD Blog. View the full article
