  1. Today
  2. Do you want to get rid of the "rename only" functionality? If it were me, I'd add the new functionality near the end, after all the validating and bookkeeping is done. In the line with the sssetfirst command (not at that exact spot) the completed copy is added to the current selection set. You could expand that clause to ask for the new location and move the new block from its current location to the new coordinates. Disclaimer: I am only a hobbyist programmer, someone else may find a better solution.
  3. I need to select a block in the drawing, insert a copy of the block at a specified point, and rename the copy.
  4. I had code that would pull from network location if you want a specific type of block. just remember if a block is already defined in the block library of the drawing it will use that instead of fully importing it again. -edit Might want to use steal instead. https://www.lee-mac.com/steal.html
  5. Hi, everybody. In this code, a copy of the block is superimposed on the original, how to change the code to insert a copy of the block at the specified point. ;;-----------------=={ Copy/Rename Block Reference }==------------------;; ;;----------------------------------------------------------------------;; ;; Author: Lee Mac, Copyright 2013 - www.lee-mac.com ;; ;;----------------------------------------------------------------------;; ;; Version 1.5 - 05-07-2013 ;; ;;----------------------------------------------------------------------;; (defun c:cb nil (LM:RenameBlockReference t)) (defun c:rb nil (LM:RenameBlockReference nil)) (defun LM:RenameBlockReference ( cpy / *error* abc app dbc dbx def doc dxf new old prp src tmp vrs ) (defun *error* ( msg ) (if (and (= 'vla-object (type dbx)) (not (vlax-object-released-p dbx))) (vlax-release-object dbx) ) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ) (princ) ) (while (progn (setvar 'errno 0) (setq src (car (entsel (strcat "\nSelect block reference to " (if cpy "copy & " "") "rename: ")))) (cond ( (= 7 (getvar 'errno)) (princ "\nMissed, try again.") ) ( (= 'ename (type src)) (setq dxf (entget src)) (cond ( (/= "INSERT" (cdr (assoc 0 dxf))) (princ "\nPlease select a block reference.") ) ( (= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (cdr (assoc 8 dxf))))))) (princ "\nSelected block is on a locked layer.") ) ) ) ) ) ) (if (= 'ename (type src)) (progn (setq app (vlax-get-acad-object) doc (vla-get-activedocument app) src (vlax-ename->vla-object src) old (vlax-get-property src (if (vlax-property-available-p src 'effectivename) 'effectivename 'name)) tmp 0 ) (while (tblsearch "block" (setq def (strcat (vl-string-left-trim "*" old) "_" (itoa (setq tmp (1+ tmp))))))) (while (and (/= "" (setq new (getstring t (strcat "\nSpecify new block name <" def ">: ")))) (or (not (snvalid new)) (tblsearch "block" new) ) ) (princ "\nBlock name invalid or already exists.") ) (if (= "" new) (setq new def) ) (setq dbx (vl-catch-all-apply 'vla-getinterfaceobject (list app (if (< (setq vrs (atoi (getvar 'acadver))) 16) "objectdbx.axdbdocument" (strcat "objectdbx.axdbdocument." (itoa vrs)) ) ) ) ) (if (or (null dbx) (vl-catch-all-error-p dbx)) (princ "\nUnable to interface with ObjectDBX.") (progn (setq abc (vla-get-blocks doc) dbc (vla-get-blocks dbx) ) (vlax-invoke doc 'copyobjects (list (vla-item abc old)) dbc) (if (wcmatch old "`**") (vla-put-name (vla-item dbc (1- (vla-get-count dbc))) new) (vla-put-name (vla-item dbc old) new) ) (vlax-invoke dbx 'copyobjects (list (vla-item dbc new)) abc) (vlax-release-object dbx) (if cpy (setq src (vla-copy src))) (if (and (vlax-property-available-p src 'isdynamicblock) (= :vlax-true (vla-get-isdynamicblock src)) ) (progn (setq prp (mapcar 'vla-get-value (vlax-invoke src 'getdynamicblockproperties))) (vla-put-name src new) (mapcar '(lambda ( a b ) (if (/= "ORIGIN" (strcase (vla-get-propertyname a))) (vla-put-value a b) ) ) (vlax-invoke src 'getdynamicblockproperties) prp ) ) (vla-put-name src new) ) (if (= :vlax-true (vla-get-isxref (setq def (vla-item (vla-get-blocks doc) new)))) (vla-reload def) ) (if cpy (sssetfirst nil (ssadd (vlax-vla-object->ename src)))) ) ) ) ) (princ) ) ;;----------------------------------------------------------------------;; (vl-load-com) (princ (strcat "\n:: CopyRenameBlock.lsp | Version 1.5 | \\U+00A9 Lee Mac " (menucmd "m=$(edtime,$(getvar,date),YYYY)") " www.lee-mac.com ::" "\n:: Available Commands:" "\n:: \"CB\" - Copy & Rename Block Reference." "\n:: \"RB\" - Rename Block Reference." ) ) (princ) ;;----------------------------------------------------------------------;; ;; End of File ;; ;;----------------------------------------------------------------------;;
  6. vudungcom
    Batch print to pdf
    Hello, You can try this by using accore, super fast and no UI
  7. SLW210
    Retro Error Backtrace
    You might want to look into using Visual Studio Code, it is replacing the VLIDE in newer AutoCAD versions. I have some links to more information in this thread...
  8. Cliff
    Thanks again. I just need to remember that CNTL F9 only works when I do not mouse-click on vlisp console first.
  9. Cliff
    Thanks. Good stuff there.
  10. Lee Mac
    Perhaps my tutorial on debugging with the VLIDE will help? https://lee-mac.com/debugvlide.html
  11. Cliff
    Thanks for responding. That is correct. I put (vl-bt) in my *error* functions, otherwise I have zero idea where the error occurred. However, I don't know the name of the variable in the errant line of code, only the values. That isn't always easy to spot. I was able to load and run code thru the vlide, but using CNTL-F9 did not show the line where the error occurred, just this dialog. And setting "Break on Error" didn't do what AI told me it would...When it crashes, VLIDE will freeze the execution and highlight the problematic line in your source code.
  12. Lee Mac
    FWIW, the output you are describing comes from the undocumented (vl-bt) function, e.g.: (defun c:test ( / *error* ) (defun *error* ( m ) (vl-bt) (princ)) (/ 1 0) ) Command: TEST Backtrace: [0.50] (VL-BT) [1.46] (*ERROR* "divide by zero") LAP+7 [2.40] (_call-err-hook #<USUBR @0000021d551441b0 *ERROR*> "divide by zero") [3.34] (sys-error "divide by zero") :ERROR-BREAK.29 "divide by zero" [4.26] (/ 1 0) [5.20] (C:TEST) LAP+33 [6.15] (#<SUBR @0000021d55144278 -rts_top->) [7.12] (#<SUBR @0000021d532d8700 veval-str-body> "(C:TEST)" T #<FILE internal>) :CALLBACK-ENTRY.6 (:CALLBACK-ENTRY) :ARQ-SUBR-CALLBACK.3 (nil 0)
  13. Yesterday
  14. mhupp
    https://www.afralisp.net/visual-lisp/tutorials/visual-lisp-editor-part-1.php
  15. If you have the AutoCAD .dwg all you have to do is Modify>Solid Editing>Delete Faces. If stuck with the 3MF file, your 3D Printer software and and filling the hole with a cylinder would probably be the only way. I could have redrawn that in AutoCAD without the holes in the time it took me to type this response.
  16. CyberAngel
    MycadHELPER
    Impressive resume, I look forward to looking at the site and your distilled wisdom
  17. Cliff
    Thank you for the reply, but sad to say I do not even know how to execute a program from the vlide.
  18. GLAVCVS
    Hi If you need to locate where the error occurred during execution, once it has happened, press CTRL-F9 and VLIDE will show you the expression where the error occurred, highlighted. I hope this answers your question correctly
  19. A 3MF (3D Manufacturing Format) file is an advanced, XML-based file type designed specifically for 3D printing and additive manufacturing. It was created to replace the older, limited STL format. Looks to be Solidworks from the extension of the sub parts(.SLDPRT), you need to update the plate sub part. --edit nm looks to be STL. convert the plate stl over to a solid. then you can edit. --edit edit or slice it if its flat and extrude into the thickness getting rlx vibes for some reason
  20. Back in the day (Autocad 14 or so) the autolisp interpreter would spit out the variable names in the line of code that bombed instead of the values (example below), making it much easier find the problem. This may be a newbie question from an old-timer. I never took the pains to learn the VLIDE. Is there something there that solves the problem? Error: bad argument type: numberp: nil Backtrace: [0.57] (VL-BT) [1.53] (#<SUBR @0000018680e21a98 -lambda-> "bad argument type: numberp: nil") [2.49] (ill-fun-hk "bad argument type: numberp: nil") [3.44] (((MSG) (IF (NOT (MEMBER MSG (QUOTE ("console break" "Function cancelled" "quit / exit abort" "")))) (PROGN (PRINC (STRCAT "\nError: " MSG)) (IF *DEBUG* (VL-BT))))) "bad argument type: numberp: nil") [4.39] (_call-err-hook ((MSG) (IF (NOT (MEMBER MSG (QUOTE ("console break" "Function cancelled" "quit / exit abort" "")))) (PROGN (PRINC (STRCAT "\nError: " MSG)) (IF *DEBUG* (VL-BT))))) "bad argument type: numberp: nil") [5.33] (sys-error "bad argument type: numberp: nil") :ERROR-BREAK.28 nil [6.25] (- nil 8.48089) [7.19] (C:GT) [8.15] (#<SUBR @0000018680872c50 -rts_top->) [9.12] (#<SUBR @00000186807c8700 veval-str-body> "(C:GT)" T #<FILE internal>) :CALLBACK-ENTRY.6 (:CALLBACK-ENTRY) :ARQ-SUBR-CALLBACK.3 (nil 0)
  21. Lee Mac
    Incremental Numbering Suite
    I've now updated this program to support resetting components of the incrementing string back to a given value with a given frequency - the latest version can be downloaded from my site: https://lee-mac.com/numinc.html
  22. We need to know what program you are using to alter this to help you. Do you have the .dwg? Easy enough to fix in AutoCAD with a .dwg.
  23. Last week
  24. Can not open may be just my software. What software did you use to make the object ?
  25. BIGAL
    MycadHELPER
    Welcome aboard looks very interesting had a look at the link. Where I used to work we used POP menu's extensively as well as custom commands, This menu had around 130 lisps behind it. I read about workspaces and yes we would save a workspace under each users name, so it was customised to their liking. One thing I did was add a pop menu that had options from another workspace we had CIV3D, so no need to even change workspaces for some often used commands. Then of course there was custom toolbars, if you can use Notepad you can make toolbars and pop menu's. You may be interested in the attached. How to make POP menu.docx
  26. I need to remove the holes in this plate. just like they were never there. I tried making a cylinder and filling it in and it didn't look right I tried a bunch of suggestions from AI and that was a waste of time. If you cant open the 3MF file I can possible get a different older version Mark Macey front plate.3mf
  27. PGia
    Boundary command
    Yes, I suppose that, as a last resort, it is always possible to select all the linear objects until the perimeter is closed. But this can be quite slow in many cases — especially when you have many boundaries to work with. It’s an important limitation. I’ll try to find out what can be done with regions. I’m not familiar with BricsCAD. But this may end up being yet another reason to give it a try.
  28. Hi I am a retired architect with about 40 years professional practice, 30 of which have been focused on AutoCAD as a senior CAD technician and CAD manager in a large office and as a tertiary level teacher of architectural technology and building including a few years teaching AutoCAD at TAFE and QUT. I am wondering whether some of the work I have done developing CAD drawing strategies and support programs might be useful to help AutoCAD users both at beginner level and advanced 2D drafting. What I have to offer will be best explained on my website mycadhelper.com that I have recently been reviewing as a retirement hobby. There are several topics/pages that describe philosophies for the creation of command-aliases, reduction in command-entry-keystrokes, expanded command functionality, a practical automated layer-naming-standard-and-management system allowing coincident-overlay-drafting that focuses on production drawing work-zones. The most obvious aspect of MycadHELPER and its entry point is its clean-screen and keyboard-only input of commands and data supported by its custom carefully designed system of command aliases. I would be interested if anyone, after visiting my website, wishes to use some of my suggestions or even help in polishing it up. mycadhelper.com
