How to get rid of light dots?? (usign 3ds max , vray)
anaok
Hi guys
I am using VRayPhysicalCamera for the first time.
when I used the standard camera,I had no problems becouse the picture was good
but when I used the VRayPhysicalCamera , the picture had has a lot of light dots
can you help me how to get rid of light dots ?
I used autocad 2010 , 3ds max 2010 , Vray 1.5 sp5 to make this picture.
Thank you
well physical camera can be pain if your not familiar with basics of real life photography (aperature, f-stop etc). also bare in mind that vray lights behave diferentlly when using P-camera. im guessing you placed a camera in front of the glass, so you should check your refraction subbdivision for the glass, (take it up to 20 or so), post your gi settings (light cashe and iridiance map settings). and if your getting good resaults with normal camera i see no reason to bother with physical camera, it does give you more freedom but as said if your not verry good with real life photography it just adds more complications to your rendering setup. cheers
OMG your work is very good. Keep it up. You have done a tremendous job. I do not much about this but i think you can heal the dots in photoshop i guess.
No, it's a problem with the render settings. Fixing this image in Photoshop would take ages.
Thank you very much for your encouragement :):)
The problem was solved, you were right the problem was with the render settings.
check "sub pixel mapping" on the color mapping tab. (Note: when I turn sub-pixel mapping on only , I got rid of light dots)
If anyone wants more information open this link
http://forums.cgarchitect.com/28616-white-dots-my-vray-rendering-help.html
V-Ray for 3ds Max official help index
http://www.spot3d.com/
Tnak you.:D
Hi minks thank you for reply
you are right that I put a camera in front of the glass, but I did everything you said for glass before I read your reply. I think that made glass with wrong reflection and refraction setting like (IOR , color selector
I want to learn how to create vray glass well . I found tutorials (V-RAY MATERIAL SETTINGS , Rendering Glass and Liquid) *.pdf by author Wouter Wynen
These tutorials can be found : under (Chaos Group)
http://commerce.vismasters.com/download/view/type/?dtid=2 (*.pdf , zip)
or
http://designmeet.com/index2.php?option=com_docman&task=doc_view&gid=20&Itemid=44
http://st.free-lance.ru/users/Zelen/upload/f_496fa34f84716.pdf
I agree with you that physical camera can be pain if we do not know basics of real life photography.
