harald72 Posted October 28, 2011 Share Posted October 28, 2011 Hi, I'm using AutoCad 2010. I have received some plan drawings that I'm supposed to do some additional work to. I've found that some of the lines and texts have different z factors. They look really messy in other views than plan view. Is there a command that can put all the work into the same plane, preferably to the xy plane, z = 0? I know there is a command that can flatten 3d views into a 2d drawing but that doesn't seem safe in this case. I know there is such a command in for example Rhino (flatten artwork) but in AutoCad I've never come across it. H Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 28, 2011 Share Posted October 28, 2011 You could try the FLATTEN command or you can try the old CHANGE command and utilize the ELEVATION option (set it to "0"). If neither of those work there is a macro that is frequently posted here that will do the trick as well. As a matter of fact it may very well appear in one or more of the similar threads listed below. Quote Link to comment Share on other sites More sharing options...
Rebel Posted October 28, 2011 Share Posted October 28, 2011 Point filters are another option. You can set your point filters to only move the objects along the z axis and move them to z0 Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 28, 2011 Share Posted October 28, 2011 Express Tools > FLATTEN Use: via command line "You can use FLATTEN to create a 2D drawing from a 3D model or you can use it to force the thickness and elevations of selected objects to 0." Quote Link to comment Share on other sites More sharing options...
harald72 Posted October 28, 2011 Author Share Posted October 28, 2011 Thanks. I've used FLATTEN and it worked. Only, in one of the drawings it made arcs into straight lines. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 28, 2011 Share Posted October 28, 2011 You'll have to take that up with AutoDesk. We just give out advice we don't do the programming. Quote Link to comment Share on other sites More sharing options...
Organic Posted October 29, 2011 Share Posted October 29, 2011 Perhaps check with whoever sent you the drawing first about whether you can flatten it. Some of the items may have different z heights as it is 3d survey data. Quote Link to comment Share on other sites More sharing options...
