Move layout-Rename layouts- Goto layout
BIGAL
Working on a big project and found moving around the layouts frustrating so created some layout lisp to make life easy.
Goto jumps to any layout like word etc by page number
Move layouts- moves current layout to a new position by its number position, Model is 0 and starts at layout1
; go to any layout by its page number
; By Alan H Feb 2014
(defun C:goto ( / alllayouts lay x num)
(setq num (getint "\nEnter tab number"))
(setq alllayouts (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object))))
(SETQ LAYNUM 0)
(vlax-for x alllayouts
(Setq laynum (+ 1 laynum))
) ;total number of layouts
(if (> num laynum)
(setq num (- laynum 1))
(vlax-for lay alllayouts
(if (= num (vla-get-taborder lay))
 (setvar "ctab" (vla-get-name lay))
) ; if
) ; for
) ; defun
(C:goto)
; renames multiple layout tabs when auto created
(DEFUN ah:rentabs ( / ans plotabs tabname)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vlax-for plotabs (vla-get-Layouts doc)
 (setq tabname (vla-get-name plotabs) )
 (princ (strcat "\n " tabname))
 (setq ans (getstring "\nEnter new name"))
 (if (/= ans "")
   (vla-put-name plotabs ans)
(AH:rentabs)
; move the current layout to a new location by tab No
; By Alan H 2014
(defun C:Mtab ( / lay num)
(setq curtab (getvar "ctab"))
(vlax-for lay (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object)))
(if (= curtab (vla-get-name lay))
(vla-put-taborder lay num)
) ; if
) ; for
) ; defun
(c:mtab)
; Got to a layout by its page name
(defun C:layname ( / lay laynam)
(setq layname (getstring "\enEnter tab name "))
(if (= layname (vla-get-name lay))
) ; if
) ; for
) ; defun
(C:layname)
Edited by BIGAL
  • 4 weeks later...
Just thought I would add another plot a range of tabs bit like publish but without having to select
;Plots layouts by range
(defun AH:pltlays ( / lay numlay numend)
(setq numlay (getint "\nEnter Start tab number"))
(setq numend (getint "\nEnter last tab number"))
(setq len (+ (- numend numlay) 1))
(repeat len
(if (= numlay (vla-get-taborder lay))
) ; if
) ; for
(setq lay nil)
(princ name)
(COMMAND "-PLOT" "Y" "" "\\\\PRODPRN03\\lase a3" "A3 (297 x 420 mm)" "m" "LANDSCAPE" "N"
"W" "-6,-6" "807,560" "1=2" "C" "Y" "DesignLaserCOLOUR.ctb" "Y" "N" "N" "N" "N" "N" "y")
(setq numlay (+ numlay 1))
) ; end repeat
); defun
(AH:pltlays)
  • 1 month later...
Maybe some one can help the goto layout works really well project with 62 sheets etc only little hiccup it would be nice if when you go to a layout it centered the current layout name in the screen seems to go either full left or right. Any ideas anyone ?
I posted this a while ago the only way I can get what I want is by using the arrow on the layout row scrolling a few tabs to the left etc I did observe if you go a lower tab it sets the current layout to the left if higher sets to the right. Any one have an idea how to get at these arrows.
Edited by BIGAL
