Hello,
I have a series of MTEXt entities that represent coordinates to 4 decimal places. Now I need to convert them all to three decimal places.
The only option at the moment is to manually edit them.
Im just wondering if there are quicker ways to carry out this process such as converting them to blocks and trying to make a table from them (only just this second had the idea).
Any suggestions or referals to marco/lisp routines?
I was about to recommend a table but you already have had that idea.
I don't think converting them to blocks will give you any gain in functionality.
It is possible to trim them using LISP (but I couldn't do it right now) or VBA.
I have just pulled about a similar routine from my colection to give you this.
Private Sub SigDig()
Dim myText As String
Dim returnObj As AcadObject
Dim basePnt As Variant
ThisDrawing.Utility.GetEntity returnObj, basePnt, "Select an object"
   If returnObj.EntityName = "AcDbText" Then
   'do this
   myText = FormatNumber(returnObj.TextString, 2)
   returnObj.TextString = myText
   returnObj.UpDate
   End If
End Sub
This only works on DText but shows the form. The significant digits is the last number in the myText= row.
If i explode the Mtext I wont lose any required functionality; which should bring your routing into play nicely. Thanks for that.
What I was thinking with the blocks was to export the attribute text. But first I would need to convert text to attributes. If you anyone has a LISP for this I am sure it would come in handy on numerous future occassions.
my routine will work on MText (with a small mod) but will treat the MTEXT as a single number. If the MTEXT doesn't start with a number it will return 0.00 and if there is a list of numbers only the first will be returned so exploding to text may be just as easy. Howmany numbers do you have to convert and does the MTEXT only contain one number?
If you have exploded all your coordinates to text, then use this lisp TextMath. It allows variable places of decimals as output, so you could add zero. :)
Textmath.lsp
I exported some coordinates using EATTEXT.
The table needed to be modified to drastically for the table editing options to allow. So I exploded the text and set it up how I wanted.
The engineer then says 4dp is too much. Can I make it 3DP?
So there are approx 200 instances of MTEXT that are similar to this: 1223.4445. This example would need to appear as 1223.445.
good man.
Using this to multiply by one works perfect.
You will be getting a christmas card this year:) .
  • 4 months later...
How do I Convert / Explode mtext with field values to Single Line text and still keep the fields values?? Any LISP for this? :unsure:
