Showing results for tags '(lisp expression)'.
  1. Having already asked with no replies some time ago, I thought I could give it a try once again. When I run my lisp routine which begins with (command "_.undo" "_BE") and ends with (command "_.undo" "_E") and for any reason I press "u" I get the annoying message (Lisp Expression) multiple times at the command prompt. Is there a way to hide this repeated message or get rid off it with any other way? Thank you.
