Showing results for tags '2 dimensional'.
  1. Hi, I'm new to the Forums and this is my first thread. I have been assigned to draw an isometric and 2 dimensional view of a sprocket. It has to be to scale with the sprocket given to us. I can't figure out how to measure it, much less start it. My guess is to start with the center, but I can't even measure that. When I figure out how to post a picture, I will. What I can tell you so far is that all I am permitted to measure with is a 6" CEN-TECH Dial Caliper. Not sure of the name, but I can describe the center hole(s). The center looks like a gear with 6 (flat) teeth. Above that (I eyeballed the bottom of it at about 1/8 in. away from top of center) is a circle that my caliper reads at 0.276 in. in diameter. It has 14 teeth. Sorry for the long explanation, but I want to make sure the responses can be accurate as possible. When I get the pic, I'll post it. On this thread. THANKS SOOO MUCH!!!
