Showing results for tags '3d face'.
  1. Hi guys, I need help! How can I EXPLODE a polyface MESH to 3D Face BUT keep original colors. I would appreciate it if you help me to solve the problem. DWG file attached. Kind Regards, Mirzali Jafarov Profile IP Line01.dwg
  2. Very usefull tool to transform 3D Faces To Solid ! ...or a 3D terrain model to a sectionable solid http://www.sharedengineering.com/index.php/13-download/autolisp/20-autolisp-to-transform-3d-faces-to-solid >>> http://www.sharedengineering.com
  3. Hi all, I have surveyed some pipes below the ground and I need to represent these as 3d polylines in Autocad below a ground surface model. Is there a routine that will let me add a z value to each vertex along a 3d polyline line which references a 3d face/ground model above to give me a true z value directly below the ground level. Any Ideas???
