Showing results for tags 'batch print'.
  1. Help!!!!! I have just switched over to 2014 and i cannot for the life of me get my batch plot to plot PDF's to a single file! Instead, it's printing all 37 layouts separate. I tried switching between multi-file & single file in the publish options, but nothing! I cannot remember what the trick is.....i know that it took me a while to perfect my settings the last time i set up a new version, but i am struggling to work it out now. I find the setting for batch plot not very user friendly at all....
  2. Hey guys, Good day. first time im using scriptpro. I am doing about 400plus drawings and I need help on Batch freezing of rev clouds and triangles and Printing to pdf using Scriptpro. Do you have a script that runs in scriptpro that i can use? Autocad abs 2006 Layer to freeze "*REV*" Print to pdf and I'll just rename the pdfs. thanks a bunch
