Showing results for tags 'bring to front'.
  1. I've used AutoCAD for years and I've never had this problem. On one of my sheets I have a Location Map showing the general area of the construction project in a viewport. Then I have another viewport showing the state map which is suppose to sit on top the Location map. I also have some text (not in a viewport but on the sheet itself) with an arrow pointing to the project area. The problem is no matter which display order command I use: the text, arrow, and state map always disappear under the Location map. But the Location map should be under everything. I've exhausted my mind trying to figure out how to resolve this -- even re-creating the viewports and whatnot to no effect. Please help
  2. Hi, I'm new and self taught on cad (so sorry if i appear dumb) I've used cad now in a basic 2d architectural sense now for 10 years, through various versions. I have recently dropped back to a 2007 from 2008 (changed jobs) and for some reason the draw order is all messed up i noticed this first through hatching but its on everything including inserted images. I've tried a few of the solutions on other threads even uninstalling cad and re-installing it and nothing seems to be sorting it. Functions like 'send to back' etc just don't work and the draw orders are all to pot. Any ideas ?
  3. i am using autocad 2009. draw order options like 'send to back' or 'bring to front' , for solid hatch, are not working in my drawing.. previously they used to work. bt nw they r nt working in that same file. tried all possible ways..
