Showing results for tags 'cloth realism covering'.
  1. Hi! My name is Pavel. My issue is the following: I need to cover a body with a sheet. The problem is that the sheet is covering body too tightly. (the image is attached) What parameters should I change in cloth modificator, so it will look real Thank you in advance, Pavel.
