Showing results for tags 'color control'.
Everything I draw is the same color!
armcrae posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
No matter which layer is current, everything I draw is the same color. Does anyone have a simple fix? I am using AutoCAD 2014. -
When I highlight any object in model space the layer control, color control or line type control does not change from the current layer status to the layer of the high lighted object if it is different. I am also not able through this layer control bar able to high light an object and use the fly out arrow to go into the layers and change this object to another desired layer for this object. I have never seen this function just not work before and can find no setting or preference that might not be turned on to make it function. Does anybody have any ideas to why it is not functioning?
- 3 replies
- layer control
- color control
