I am using Autocad 2007. Cannot get the all lines and text to plot correctly, some are correct but some are way too thick as though they are potting by thickness and not color. I changed the color and they still plot thick. In checking the properties box they all seem to be the same. Tried blocking and got the same. It also creates the thick lines when I create a PDF. I think the original drawing was created in ProCAD. Could it be holding the original default and if so how do I reset them back? When I plot in monochrome they are better but still some lines come out wrong.
