Showing results for tags 'command window'.
  1. Ever since installing the 2019 version of Civil 3D, my command window will not stay docked. I am asking for help at this point because I do not know what else to do and have scoured the web in search of answers and have tried just about everything I can think of. Before all the usual suggestions come pouring in, here's what I have tried so far: (1) I changed STARTUP to 0 and docked the command window. This did nothing. (2) Next I locked everything. LOCKUI setting was changed to 15 which is supposed to lock toolbar, panels, floating toolbars and windows in place. No effect on my command window which is undocked every time I open AutoCAD (3) I made sure to automatically save my workspace settings (WSSETTINGS). No change. (4) Then I changed WSAUTOSAVE to 1. I docked the command window. The opened CUI, found my workspace --> opened Palettes --> Opened Command Line --> and set the properties of the command window Orientation to "Do not change", of the Allow Docking to "Do not change". Not only did this not work, but the CUI settings reset. What else can i do?
