Showing results for tags 'contour lines'.
  1. PaddlesUpRiver
    Can't Label Combined Surface Contours
    I've never had this issue before and it's beginning to drive me bonkers! I have a combined surface that I've created from an existing topo file and a couple of new survey files. But I cannot label my new surface. When trying to add a single (or multiple) contour label, the drawing will not allow me to select the surface or a contour line. I can click my cursor all over the place and it will not select the surface, and I have to hit Escape to exit the command. Once I am out of the command, the surface is easily selectable, but for some reason it will not let me label it. How do I label this surface?
  2. Hello people, I think this is my first post here but I've been reading the forums since 2012. Right now I'm trying to create a 3D terrain from the contour lines I got, using the DRAPE command. I followed a very simple video tutorial that basically you got all the contour lines equidistant from each other on the Z axis, and select all then DRAPE command and it creates a clean solid 3d terrain. I use Autocad for Mac, and the command isn't working at all, it says it's doesn't exist. Is this normal? I really need this terrain on 3D so I can deliver it to the CNC machine. What are my options? File attached*[ATTACH]64364[/ATTACH] Thank you very much, I hope I posted in the right section. Terreno para maquete 3D (2007).dwg
