Showing results for tags 'copy paste problems'.
  1. I'm having a lot of problems with a set of drawings that are getting bigger and bigger. When I started working on them they where about 800kb - with no mayor changes the file has grown to 13000kb. They problem starts when I paste from one file into the next - even though is just one block or one line the file allmost dobble is size (as a test I tried in a earlier version of the file - when I pasted in one line the file grew from 800 to 2300kb) I'm working in Autocad 2012 in 2D. In the drawings where is about 3-4 x-refs, no layer filters, a lot of layers (all used), a lot of blocks and a few hatches. I've done purge, -purge, audit, copy/paste into new document, saved in earlier version. Any good ideas out there? Thx!
  2. Hello, I am working with a couple different drawings in AutoCAD 2007, and pasting items between them. For some reason, I am unable to use object snap on items that have been pasted into the main document from one specific file. I am able to use OSNAP on these items if they are pasted some where else, but not the specific file that I am working on. I cannot restart the original file, because I have too much work done already. I have tried closing the file and reopening it, but that hasn't helped. Any other suggestions? Thank you!
  3. Hello Folks, I am using auto cad 2014 & I am trying to copy some Template file in new sheet but its not coming, I need it very urgent!! please help me out
