Showing results for tags 'curved surface'.
  1. coolface man
    Stickers on inclined face
    Hi everyone i'm having issues on applying a decal on an inclined surface using inventor here's a screenshot to let you understand my situation. Using the decal tool I cant select the surface on where i put the image (the selected one, to let you understand) Thank you for the help
  2. Hi, This should (on the face of it, parden the pun) be an easy task. I created a lofted surface over 3 scketched lines. The result is a niceCAD Tutor.zip curved surface. I then thinkened the surface and converted to Sheet metal. At this point I expected to just set the sheet metal defaults to the same 6mm as my thickened surface, and create a flat pattern. But Inventor seems to not find a bend and errors!! So I try Unfold, no joy....Any one got a solution, please? .ipt attached Many thanks, Jon
