Showing results for tags 'data sets'.
  1. Hi, I am very new to lisp and AutoCAD with no previous experience. I am working on a project which I’m finding pretty difficult. What I am trying to do is import attributes and properties associated with a sphere from a .csv file into the corresponding property set in AutoCAD. I found a solution online which will allow me to import the coordinates (x,y and z) and this works a treat. However, I am having difficulty trying to import attributes associated with the sphere into the extended data property sets. So say for example, I am trying to import the week number, a reference and a description in from the .csv file into AutoCAD, under properties and extended data. Would anyone have any guidance or direction they could give me? Anything at all would be greatly appreciated. Thank you in advance!
  2. I work for a healthcare facility which has several fire and smoke walls throughout. I've created a library of the custom walls that are commonly used. Under the property sets for the walls I have created a box where the fire rating can be inputed. Now, that I have the walls set up and I want to have the doors take on the fire wall properties of the wall they are placed in. For example, if I place a door in a 3 hour rated fire door I want the door to update its property sets to show that it too is supposed to be a 3 hour rated door. I have 1 hour, 2 hour, 3 hour, and smoke rated walls and I need my doors to update their properties automatically under the "Extended Data" tab of the properties menu. Please help!!
