Showing results for tags 'data tables'.
  1. Draugnim
    SDF data table
    Hello everyone. I'm new to this forum so please forgive me if I'm doing something wrong. I would like to populate a SDF feature data table in AutoCAD Map 3D with a autolisp routine. I've been searching the internet for days and could not find any clues so I assume it's not possible to do that. So what I'm thinking now is to maybe export the data that I get from the lisp routine to some kind of database (dbf, access, excel ...) and then join it with the SDF. Does anyone have any suggestions how to that? Thanks in advance! -------- What my lisp routine does is, it selects al the parcels one by one, creates a new feature from object (new column in the data table), generates a GUID number, reads the parcel number and promts for user imput for some data that is the same for all parcels. -------- I'm confused a little bit now. The command 'New feature from object' creates a new column i the data table that is related with the coresponding parcel. When I click the column the parcel is selected. ****Will I be able to get the relation between the parcel and column if I export the data to another database and then join it with the SDF. Maybe if I let the lisp create the columns in the SDF data table for all the parcels and than later when joining the database somehow make the data go in the empty columns created by the lisp?****
  2. Hi, It's my first post in this forum, I hope this is the right place to post my question. Im using Autocad Map 2011 and I have a DWG file with hundreds of data tables (2x2) spread all over a map. All table content is in text, and they have a cell with an ID (manually inserted in autocad - in the first top/left cell) My goal is to link the data table contents to an excel spreadsheet, so that i can update table values from excel. Can someone help me? Attached its a dwg file to get the idea. Drawing1.dwg
  3. frenkas
    Acad Map 3d - Object data - tables
    Hi, I have some drawings, where i see tables object data tables. After clicking map->object data->define object data I see several tables created with interesting fields, which may contain useful information. However as I am not familiar with Acad map I can't view this data. Can anybody tell me how can I view this table data or at least give me a clue so I can begin digging in the right path.
