Showing results for tags 'delete attributes'.
  1. So I have a library full of exported blocks (wblock) Now I wanted to add an attribute to those blocks with the part name so I can use eattext. (since we use 2d blocks and they have multiple views I couldn't use the block names) And since I am not working in a block but a dwg file of and exported block. I couldn't use any standard attribute lisps. I can't even use attedit since that asks for a block too. So while I was making this post I figured it out by myself so here is the code: To add an attribute to the center of a drawing or a block if your in the block editor: (command "-Attdef" "I" "P" "L" "" "partnr" "enter part number" "partnr" "style" "style1" (getvar "viewctr") "0") to delete the old attribute ( I modified a block delete routine: (defun C:delblk3 (blk / SS FILTER SSLEN ENT) (progn (setq FILTER (list (cons 0 "ATTDEF") (cons 2 blk) ) SS (ssget "_X" FILTER) ) (if SS (progn (vl-load-com) (repeat (setq SSLEN (sslength SS)) (vlax-invoke-method (vlax-ename->vla-object (ssname ss (setq SSLEN (1- SSLEN)))) 'Delete) ) ) ) ) ) (c:delblk3 "partnr") ;; call it with this line. Sharing it because 90% is from here anyway, I hope someone finds it helpfull
