I hope you can help me,
I'm trying to create a block with attributes to handle planes reviews.
I wonder if you can do with query parameters and I can explain how I can do what I will explain:
- The idea is to first change query parameter when I want the plane pass Revision B to Revision 0, the revision C to revision 0 of the revision D to revision 0 so on until you pass the revision G to review 0 (you have all those combinations disappear without a change when realize another change)
all dates which you can change some among other without being affected no visibility and so we can combine between all options.
-There is also hidden attributes that only appear when dates are changed (ie for each date there are 2 options over date in which you want to see only when necessary)
I hope you can help me.REVISIONS.dwg
