I have started Brian Benton's tutorials and hit a problem on the second one, "Quick Run Thru". The problem is that the object drawn is too small on the screen to be useful. This was the result of drawing the 50x30 rectangle called for in the tutorial.
What setting adjustment is required to show the rectangle as it appears in the tutorial - i.e. larger on the screen so I can do something with it.
Thanks
