Showing results for tags 'entity error'.
  1. Hi, I have started to write a routine and it models what I wanted so far, except the last entity set to "HdrFtr". When I try to list data on "HdrFtr" I get this ... h *1410(1 |") (1 . "/061+ {rn rn {rn mhjqggjgoglifmkii rmmfqiimmfmokolgjjj nqj |") (1 . "/061+ {rn rn {rn mhjqggjgogligjmghl rmmiqnimmfmnkginmin nqj |") (1 . "1>2:@>++-6=r8:1r>++-6= {rn rn {rn {rn {lg 30,: 30,: >//3& ,(::/@:1;@9>1:r,*-9>Instead of this..... ((-1 . ) (0 . "LWPOLYLINE") (330 . ) (5 . "1AF") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDbPolyline") (90 . 5) (70 . 0) (43 . 0.0) (38 . 0.0) (39 . 0.0) (10 275.886 -229.662) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 I cannot figure out what I have down wrong. Can anyone help. I will attach routine so far. Thanks TESTSTUD3.LSP
  2. Guys, Attached here I have one drawing with a pline exported from another software, I receive a lot of this kind of entity with the same error, someone know's how to fix it, or it's possible redraw it with another line but as the same format!... (Try to do a offset of 20 mm about that entity, to both sides, not works) It's possible work with a lisp to redraw it? Thanks... Entity with error.dwg
