Showing results for tags 'faint image'.
  1. Hello Everyone. I really hope someone can help me. I cannot plot anything from my model space. It doesn't matter if it's in a layout and using viewports, or if I try to plot directly from model space. When plotting I get a very faint image, if anything. I know my printer is working because it will plot the title block surrounding the view port, but not the text in it. I have tried changing from monochrome, acad.ctb, greyscale, virtual pen, and none of them create a better image than a very faint picture within my title block. None of my layers are turned off or frozen in the off position. Nor does it matter if I change all the lines to black instead of the different colors of my layers. And I also updated the driver to my printer, they had an updated version of a printer diagnostic which said that my printer is fine. I hope someone else has had this problem, and solved it because I am at my wits end now. Thank you in advance for your time and support
