Showing results for tags 'group filter'.
More search options
  1. I am trying to define a group filter in AC2015 Original name upon creating is Group Filter1. When I try to change the name it gives following error message in command line -Layer Layer filter not found and in a box it says Unable to modify layers while another command is active The name I want to put is GF1. Although it appears as the name in filter tree but gave the above errors. I drag few layers inside this filter but I can't access what is inside the filter
