Showing results for tags 'hatch command'.
  1. the dimensions are in millimeters Four lines to be used to create a line whose length is 1090mm I tried creating the pattern using a Draw Hatch 12.5 tool but I have been getting this 2 errors Bad pattern definition file: Missing parameter on line 2. ? Please if anyone can help me in creating this patter I would be grateful to you !
  2. Hi, in one single file I cannot create hatches any more doing this: - hatch - select closed item - see it activated but not filled - enter - select closed item to check for hatch, but not created I can It used to work but not now. for me the file seems to be corrupted. Is there a way out except copying all in a new file? Thanks Georg
  3. Hi guys I am amateur in using Auto cad and this time face strange problem in using hatch command( solid ).When I use hatch command inside my drawing some unknown are is creating which is not in my drawing and make a separating lines between uni surface!! I am completely wondering what is going on and I even redraw every lines as poly line and used hatch command but it was useless! I am not sure but I am think it is related to some option.The related Image is uploaded to convey my problem . In addition when I export to pdf most of straight lines become somehow curvy and ruin all drawing.it dosent have enough accuracy and precision in all drawing I should draw at size of micron and nano meter. Please help me Thank u
