Showing results for tags 'layer manger'.
  1. Nenad Mutavdzic
    Layer Translation Mappings
    I'm working on the translation of a large number of Layers, from existing to new ones, according to exactly defined pattern. And all this for 1,000 drawings. Using command Layer Translator (LAYTRANS), is it possible to export Layer Translation Mappings as xls or txt file? XLS or TXT files are more editable and easier for work. Also, is it possible to import a Layer Translation Mappings into Auto CAD as xls or txt file? Is there a batch file which can convert layers in large number of drawings at the same time? Thanks
  2. Hi all, I'm trying to create a new layer in Layer Manager and when I choose color, I'll choose Red. But when I create new text on that new layer, the text won't change to Red - the properties box still says, "ByLayer". What gives? I've googled several times, but nothing really. Thanks,
