Showing results for tags 'muliple sheets'.
  1. Vanilla Autocad 2020. I have split a table and want to move the "second table" to another sheet. Is this possible? Could someone please explain the process? Any best options for splitting a long table across multiple sheets? Also, is dragging the bottom caret at the table the only way to split the table? Inventor allows you to pick a line in the table, RMB and pick Table Split. Didn't know if Autocad has a similar option.. Thank you!
