Showing results for tags 'proving survey'.
  1. Hello. We have a situation where a licensed land surveyor made a map for a land owner that was accepted by the planning department. The map depicts a fence blocking off a trail that for reasons outside this forum is actually a public trail. The surveyor says the fence is legal because it is located 300 feet from the shoreline. GPS devices we use put the distance at around 240-250 feet, not 300. But since we are not licensed surveyors, our claim is ignored. We have pdf copies of the surveyors map which have metes and bounds in degrees and feet. There are no latitude or longitude points on the map to correspond with any of our GPS data. How we can try to prove our allegation the surveyor is wrong using AutoCAD? How can we measure the shortest distance from the fence to the shoreline which is metes and bounded using AutoCAD? Thanks.
