Showing results for tags 'remove layer'.
  1. Traffic Management.dwg Hi all, Attached is a dwg file with a layers, WALL_RIGHT and KERB_TOP (at least I hope the file is attached) Can you delete layer WALL_RIGHT? Via the Purge command. I have used the Laydel comman previously but this doesnt seem to delete the object. The object is a square with two lines predruding it. The data is being put into a GIS System and it picks up the 'invisible' object (Even after Laydel has been used in the .dwg file) But I cant find the object anywhere! There are no blocks in the drawing... Can anyone figure out where the object is? If so please detail how you found it! Thanks muchly
