I need to modify a LISP routine. Here's what it supposed to do:
1. save a CAD file with the Filename - Date - Rev00- Timestamp,
2. when it saved it should be saved in two locations, one being the working directory from which the drawing was opened and then in a folder called superseded within the working directory
3. each time it is saved the date - rev - timestamp change (note the rev number needs to be incremented by 1)
4. the previous version of the file in the working directory to be deleted completely
The story so far is that we have managed to get most of the above specifications to work except that it does not include rev number in the filename and doesn't update the current directory although it creates the superseded directory and all subsequent saves using the SAV.lsp are in the superseded directory.
Need assistance with one please ...
SAV.LSP
