Showing results for tags 'select all'.
Found 4 results
  1. I Have lisp for placing slope and arrow with polyline and i want enhance this to what i need mention in my drawing file..so i have attached lisp & sample drawing file . and also want to enhance lisp for select all polyline at once, currently lisp select on object at once. thanks. Slope.lsp SLOPE SAMPLE.dwg
  2. this lisp convert polyline segments to arcs . work one line for time . i need select 1000 polylines for times. I'm new in autolisp and i do know what change in the code : (defun c:lwsegs2arced ( / massoclst nthmassocsubst v^v unit _ilp doc lw enx gr enxb p1 p2 p3 b i n ) (vl-load-com) (defun massoclst ( key lst ) (if (assoc key lst) (cons (assoc key lst) (massoclst key (cdr (member (assoc key lst) lst))))) ) (defun nthmassocsubst ( n key value lst / k slst p j plst m tst pslst ) (setq k (length (setq slst (member (assoc key lst) lst)))) (setq p (- (length lst) k)) (setq j -1) (repeat p (setq plst (cons (nth (setq j (1+ j)) lst) plst)) ) (setq plst (reverse plst)) (setq j -1) (setq m -1) (repeat k (setq j (1+ j)) (if (equal (assoc key (member (nth j slst) slst)) (nth j slst) 1e-6) (setq m (1+ m)) ) (if (and (not tst) (= n m)) (setq pslst (cons (cons key value) pslst) tst t) (setq pslst (cons (nth j slst) pslst)) ) ) (setq pslst (reverse pslst)) (append plst pslst) ) (defun v^v ( u v ) (mapcar '(lambda ( s1 s2 a b ) (+ ((eval s1) (* (nth a u) (nth b v))) ((eval s2) (* (nth a v) (nth b u))))) '(+ - +) '(- + -) '(1 0 0) '(2 2 1)) ) (defun unit ( v ) (mapcar '(lambda ( x ) (/ x (distance '(0.0 0.0 0.0) v))) v) ) (defun _ilp ( p1 p2 o nor / p1p p2p op tp pp p ) (if (not (equal (v^v nor (unit (mapcar '- p2 p1))) '(0.0 0.0 0.0) 1e-7)) (progn (setq p1p (trans p1 0 (v^v nor (unit (mapcar '- p2 p1)))) p2p (trans p2 0 (v^v nor (unit (mapcar '- p2 p1)))) op (trans o 0 (v^v nor (unit (mapcar '- p2 p1)))) op (list (car op) (cadr op) (caddr p1p)) tp (polar op (+ (* 0.5 pi) (angle '(0.0 0.0 0.0) (trans nor 0 (v^v nor (unit (mapcar '- p2 p1)))))) 1.0) ) (if (inters p1p p2p op tp nil) (progn (setq p (trans (inters p1p p2p op tp nil) (v^v nor (unit (mapcar '- p2 p1))) 0)) p ) nil ) ) (progn (setq pp (list (car (trans p1 0 nor)) (cadr (trans p1 0 nor)) (caddr (trans o 0 nor)))) (setq p (trans pp nor 0)) p ) ) ) (or doc (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))) (vla-startundomark doc) (if (and (setq lw (entsel "\nPick LWPOLYLINE...")) (= (cdr (assoc 0 (setq enx (entget (car lw))))) "LWPOLYLINE") ) (progn (setq i (fix (vlax-curve-getParamAtPoint (car lw) (vlax-curve-getClosestPointToProjection (car lw) (trans (cadr lw) 1 0) '(0.0 0.0 1.0)) ) ;_ vlax-curve-getParamAtPoint ) ;_ fix p1 (vlax-curve-getPointAtParam (car lw) i) p3 (vlax-curve-getPointAtParam (car lw) (1+ i)) lw (car lw) ) (setq enxb (massoclst 42 enx)) (while (= 5 (car (setq gr (grread t)))) (setq p2 (_ilp (trans (cadr gr) 1 0) (mapcar '+ (trans (cadr gr) 1 0) '(0.0 0.0 1.0)) p1 (cdr (assoc 210 (entget lw))))) (setq b ((lambda (a) (/ (sin a) (cos a))) (/ (- (angle (trans p2 0 lw) (trans p3 0 lw)) (angle (trans p1 0 lw) (trans p2 0 lw))) 2.0) ) ) (setq n -1) (foreach dxf42 enxb (setq n (1+ n)) (if (= n i) (setq enx (nthmassocsubst n 42 b enx)) (setq enx (nthmassocsubst n 42 (+ (cdr dxf42) b) enx)) ) ) (entupd (cdr (assoc -1 (entmod enx)))) ) ) (prompt "\n Nothing selected or picked object not a LWPOLYLINE ") ) (vla-endundomark doc) (princ) )
  3. Hi, I'm searching a lisp that selecting layers by them name. As an example I give some names: AAA_BBB_xxx AAA_BBB_xxy AAA_BBB_xyz I need to select all layers that names start as AAA_BBB. The third part of name is changing. In this case I'd like to select only this layers that name has AAA_BBB. How can I do this? Thank you for any suggestions in advance. Jakub
  4. Hi all, I'm trying to set up a button in my ribbon for a simple process I very regularly perform in AutoCAD 2010 LT. basically I want to: 1. Select everything in the model view (through an already active viewport) 2. Erase it all 3. Purge everything 4. Paste in whatever is in the clipboard memory (previously copied from a different drawing) and locate it at 0,0 coords. 5. Zoom Extents 6. Zoom out to 97% The macro below works perfectly fine as long as there were originally objects in model space to start with, but if I try this with a new file that has no model space objects (I only want one button) it stops at the 'select all' stage and refuses to continue. The error is the standard "Selecting objects...*error*" code and stops there. ^C^C_ai_selall;erase;all;^C^C_purge;a;*;n;^C^C_pasteclip;0.0;^C^C_z;e;^C^C_z;s;0.97x; Is there a way I can get this to work for both intances, when there are objects in model space AND when there are not? Michael
