Showing results for tags 'solid body'.
  1. Hi everyone, I have an stl file of a guitar neck that needs reverse engineered into surface or solid. Catia and Solidworks and Maya and Rhino, Meshlab Freecad various photoscan programs have failed, could be me,ha ha. All I need is the back of the neck and the trasitions from the head and foot like the one picture shown to run an endmill on it without violating the rest of the neck on that side.Any help would be great. Thank you for your time.
  2. Hi Everybody, Via the command area it is possible to retrieve the surface area of a solid body (Acad3DSolid). Unfortunately the area it is not a property of a solid body so I'm haveing difficulties retrieving the surface area (which I want to write to an excel file). I've tried to explode the solid which results in several regions and surfaces. Unfortunately only the regions have an area; the (curved) surfaces don't. Anybody suggestions how to get the area of some solids useing VBA? Looking forward to the suggestions!
