Showing results for tags 'solid deformation'.
  1. Hello everybody, 1) I have a solid with vertical walls. I need a solid, were some walls ar not vertical. So I need to move some vertices to the offset of top edge. Please, check a pic. (yellow edges have to be were are the red ones). I did it with construction lines, but I'm sure there is a more efficient way (with a command like offset). 2) Can I offset just a part of the solid at all? Thank you for any ideas
