Showing results for tags 'title bar'.
  1. Hallo, Im working in AutoCad Map 3D 2012 under Windows 10. I have a problem with visiniti of the name file (and drawing path). It is visible only in with reduced window, in fullscreen regime it is invisible (the title bar is white). Thank you for help. Adam Examples: reduced window with the file name and path: C....situace.dwg
  2. Hello: I'm using Windows 10 64-bit for my operating system. I have ACAD LT 2009 set up to show the full drawing file path in the title bar, but I can't see any text at all in the title bar. This leads me to ask two questions. First, is there a way to change the color of the title bar font? I haven't been able to find a setting for the font color in options, only the font itself. Second, does anyone know of a third party program that can be used to replace the default ACAD LT 2009 color scheme? If I could change the program window to match my Windows 10 O/S color scheme, then I'd have a blue title bar with white text. I haven't found any settings in ACAD LT or anything on the Web that will allow me to modify ACAD LT's default scheme. Can anyone help? Thanks
