Showing results for tags 'top down'.
  1. malindenmoyer
    "Top Down" Assembly Problem
    I have created a wing assembly using a "top down" approach. Essentially, I have planes spaced accordingly with airfoil profiles on each. I used these sketches as the "skeleton" of my model, with several features driven by the sketches. The problem is I need to delete a spline and replace it with another one, and I know that I will lose all the constraints linked to that original spline. Is there a way to avoid losing all the constraints? (I have tried replacing it, and it throws errors due to the original spline being deleted) I am trying to avoid having to go into each feature and redefine the constraints. Perhaps a solution to this problem would involve changing the name of the new spline to match the original. I have not figured out how to do this (after much research) nor do I know if its possible. Any help/suggestions is greatly appreciated.
