Showing results for tags 'wall types'.
Wall hatches showing in windows
claireaveri posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hello! I am having an issue with a window not inserting properly into a wall, or rather with the wall materials showing behind the window in seemingly random locations. I am using a modified version of a standard wall style and have tried several different types and lengths of windows with the same result in this location. Any ideas??? I am attaching a screenshot. Thank you!- 5 replies
- wall types
- hatch problem
I want to create wall types based on certain assembly types with the true rather than nominal block and brick dimensions, and add them to the wall tool palette. How do I do this? Also, the hatch for a CMU wall is a 45-degree double line. Drafting standard I am accustomed to is single line perpendicular to the wall direction. Can this be changed in the wall type?
- 3 replies
- tool palette
- hatch pattern issues
