Showing results for tags 'where is it?'.
  1. Greeting gents, I was scouting on Autocad 2009 and was looking through a way that you use constraints like you use in the 2000 LT version, But i can't find the setting as i am too new to this version. I wanted to use constraints so that two lines are parallel and right angles of the shape. The help section doesn't really help me to find the icons or the cmd for this. Is there another name would it be under in???
