Kat Posted May 7, 2009 Posted May 7, 2009 Hello everyone, I was wondering how you attach a pdf to a drawing. I can attach just about any other image file to a drawing, but it's not letting me attach a pdf. Any suggestions? Thank you!!! Quote
Kat Posted May 7, 2009 Author Posted May 7, 2009 Horray! It worked, but now, how do I verify the scale? The pdf is 11X17 and I am trying to do a 24X36 sheet. Thank you, thank you! Quote
Tiger Posted May 7, 2009 Posted May 7, 2009 The easiest way I know of is having something in that PDf that you know the scale of, and use the SCALE command to get it right. Quote
sparkyuk Posted May 7, 2009 Posted May 7, 2009 Tiger tried that myself and failed all i got was "failed to create object make sure the object is entered in the system registry", please explain the steps you did Quote
Kat Posted May 7, 2009 Author Posted May 7, 2009 I was able to scale it. I used the scale and reference command. Parking spaces and doors work best for me to scale from. Thank you for your help! Quote
Tiger Posted May 8, 2009 Posted May 8, 2009 Tiger tried that myself and failed all i got was "failed to create object make sure the object is entered in the system registry", please explain the steps you did The only thing I can think of is check what value you have on OLEFRAME - try setting 1 or 2 and see if that works. Other than that it sounds like you aren't getting the PDF in properly, but why that would be I have no idea. Quote
sparkyuk Posted May 8, 2009 Posted May 8, 2009 Tiger ? cheers did try altering that value was 2 set it to 1, but still the same, also did try 2 different ways of inserting, first way was = insert > OLE OBJECT> create new> object type> acrobat doument> OK but same error "failed to create object make sure the object is entered in the system registry" 2nd way was= insert > OLE OBJECT> create from file> browse to file> OK but same error "failed to create object make sure the object is entered in the system registry" will the pdf need to be in a cad folder or something stupid like that ? Quote
Tiger Posted May 8, 2009 Posted May 8, 2009 It does sound like it's a problem with Adobe's connection to AutoCAD... i can't help you with that unfortunatly. If you want to get to the bottom of that, I'd suggest you start a new thread and describ pretty much what you described here - more likely to get a good answer with a new thread. Quote
