After finding the VLISP bible on the net i've got some nice reading material sorted for the next few months and hopefully i can become more of a contributer here than a consumer. :oops: However, in the meatime i'd like to know if anyone can write me a LISP that will -purge -> 'all' and -audit -> 'y' in one hit, without promting me. :huh: Would like to set it up so the command is 'PNA' (Purge and Audit).
Many thanks in advance :wink:
Z
I believe this should work. I actually use "pall" as my "purge all" function :3
Also, I'm pretty sure this can be created as a macro, but I've no idea how.
(defun c:pna( / )
(command "-purge" "a" "" "n")
(command "audit" "y")
Top stuff, i was having to do this for about 150-200 drawings. You wonderfull people at CADTutor make my life that bit more bareable. :D Thanks again mate.
Z
Macro:
^C^C-purge;a;;n;audit;y;
Afteroon Lee,
How do i turn this into a Macro? Can it be done with Visual Lisp? :S
Z
Afteroon Lee,
Z
You just assign it to a button -
Right click on a button on any toolbar, go to Customise,
Under "Commands" tab, go to User-defined
Drag "User Defined Button" into the workspace and click on it.
Paste the code supplied into the "Macro" box
Nice Nice Nice! I Think i'll concentrate on devloping more of a whole perspective of LISPs before i dive into macros. Cheers for the info thou ;)
Z
No probs - if you have any other questions, just ask :)
That's my usual method
My other 'Save' button goes 'ZX, purge, save, close, open' so I can't forget to purge, and to make the whole process of working through batch edits so much quicker
