Dear all,
i had received a drawing file from our consultant. which is over all project layout. we always getting the coordinates from that drawing means which is base drawing. it is good and working well.
but the problem is when i xref this file in to a new acad template. the hole layout is moved some where else.
there is big difference between two files which is base and new file.
i had often done xref very well. but i never seen this problem.
Please anybody help me...
I am using autocad 2005
Aravindan
You'd better to check
1. insbase values
2. base values
3. are the units same for two dwg
it may work
