NuttZ Posted May 15, 2009 Share Posted May 15, 2009 Been messing around with the new MEP and it kind of drags it feet a little. Anyone else mess around with MEP 2010 think its runs a little slow...have any suggestions or setting changes that might speed it up. I'm running a well set up PC...so it’s not a lack of computer performance. Quote Link to comment Share on other sites More sharing options...
LifeoRiley0 Posted May 15, 2009 Share Posted May 15, 2009 W are using MEP 2010 and upgraded from MEP 2009 and I find it actually runs faster. Do you use X-Refs? Quote Link to comment Share on other sites More sharing options...
NuttZ Posted May 15, 2009 Author Share Posted May 15, 2009 Yeah, we use xref's. It seems like it pauses between commands a lot. Its probably just me thinking its running slow. I didn't know if anyone else had any issues. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted May 15, 2009 Share Posted May 15, 2009 MEP definitely has some performance hits. I've experienced them since I've been using it from version 2008. When are you experiencing the slow performance issues? Quote Link to comment Share on other sites More sharing options...
LifeoRiley0 Posted May 15, 2009 Share Posted May 15, 2009 Our drawings used to bog down terribly using "attached" X-Refs. We recently started using "overlay" and that has helped a lot. Quote Link to comment Share on other sites More sharing options...
NuttZ Posted May 15, 2009 Author Share Posted May 15, 2009 It's mainly with selecting objects...once you click the object (block, line, or AEC) it gets a pause...then takes off. Also, with the ribbon...switching between tabs is gets a long pause. It's mainly little things...but it gets a little frustrating. I didn't know if there was a new setting that came with 2010 that would effect something to that nature. Quote Link to comment Share on other sites More sharing options...
aczeller Posted May 22, 2009 Share Posted May 22, 2009 mine seems to run fine. I have noticed that the crashes are few and far between now compared to 2009, but it still has it's issues. Overall, i think it is a much nicer, faster, and cleaner version than 2009, however i REALLY wish that we didn't have to download anything to get rid of the stupid ribbon... i HATE that thing. I hate it in MS Office programs, and i hate it even more here. Later, Andy Quote Link to comment Share on other sites More sharing options...
LifeoRiley0 Posted May 26, 2009 Share Posted May 26, 2009 however i REALLY wish that we didn't have to download anything to get rid of the stupid ribbon... Later, Andy I just went to "window" and deselected the ribbon and then loaded my old CUI with all the toolbars. Works Great.... Quote Link to comment Share on other sites More sharing options...
NuttZ Posted May 27, 2009 Author Share Posted May 27, 2009 I just went to "window" and deselected the ribbon and then loaded my old CUI with all the toolbars. Works Great.... Thats awesome...where is "window" I know that the ribbon can be closed by RIBBONCLOSE. How did you load your old CUI? Did you just load your old profile setting. Did it bring back the pull down's that are at the top? Thanks Quote Link to comment Share on other sites More sharing options...
LifeoRiley0 Posted May 27, 2009 Share Posted May 27, 2009 How did you load your old CUI? Did you just load your old profile setting. Did it bring back the pull down's that are at the top? Thanks When I installed 2010 it asked me if I wanted to migrate my settings from 2009. It brought over 90%. I also save my CUI to our srever "just in case" Yes it did bring back the pulldowns. Can you save your CUI from 2009 and load it into 2010? Quote Link to comment Share on other sites More sharing options...
NuttZ Posted May 27, 2009 Author Share Posted May 27, 2009 It asked me to migrate as well, but I really didn't see where it brought anything from 09. I will try and save and load it. When I type "Menubar" in 2010 to bring up the menu bars...it says no menus are defined. edit: It didn't bring in my tool bars or my menu's....I exported my 09 profile and imported it in 2010. I can just make my tool bars...it will take some time....It seems that is what I may have to do. Quote Link to comment Share on other sites More sharing options...
LifeoRiley0 Posted May 27, 2009 Share Posted May 27, 2009 Have you tried to customizing your current CUI? Quote Link to comment Share on other sites More sharing options...
NuttZ Posted May 27, 2009 Author Share Posted May 27, 2009 This is what my CUI page looks like...it seems from looking at yours...It didn't migrate right. I am going to try and migrate my settings again and see if it brings everything in. I have modified the ribbon...and started adding tool bars, but I hate to take the time to redo my tool bars if i can get them to migrate. Quote Link to comment Share on other sites More sharing options...
LifeoRiley0 Posted May 27, 2009 Share Posted May 27, 2009 Go to the transfer tab and transfer your CUI to the current Quote Link to comment Share on other sites More sharing options...
NuttZ Posted May 27, 2009 Author Share Posted May 27, 2009 That worked...when I type "menubar" hit 1 to show the menu bar...it only shows my express tool pull down. Also, how do I show my tool bars....there are none on my desktop and i can't right click on to add them. the transfer tab worked. Quote Link to comment Share on other sites More sharing options...
LifeoRiley0 Posted May 27, 2009 Share Posted May 27, 2009 I right click the area where my toolbars are and a drop down comes up and I can check/uncheck the toolbars Quote Link to comment Share on other sites More sharing options...
Zorg Posted May 27, 2009 Share Posted May 27, 2009 Its still just not as good as CADDuct Quote Link to comment Share on other sites More sharing options...
NuttZ Posted May 27, 2009 Author Share Posted May 27, 2009 I right click the area where my toolbars are and a drop down comes up and I can check/uncheck the toolbars Thats how I alway have done it as well...but when there are no tool bars up...it doen't give you that option. Quote Link to comment Share on other sites More sharing options...
NuttZ Posted May 31, 2009 Author Share Posted May 31, 2009 I leave my Properities palette...and when I close it out 2010 runs awesome. Any ideas why? Quote Link to comment Share on other sites More sharing options...
GolfBum Posted May 31, 2009 Share Posted May 31, 2009 Its still just not as good as CADDuct That is an understatement i would say it far from being anything close Quote Link to comment Share on other sites More sharing options...
